All lights flash when the machine starts, after a few minutes the lights resume the normal operation and the machine operates as it should.
There also seems to be a balance problem as the machine vibrates excessively when spinning usually at the start of a spin cycle and continues to vibrate at a lower frequency during the rest of the spin cycle.
If this is a washer dryer the filament can become loose on the dryer side of things and just rattle about inside i have just sorted out mine!!!! :-)
Try a different socket and try not to use extension leads if the lights continue to flash do not worry for now . the balance problem could be uneven load . or get some one to remove top and check support springson top and dampers at bottom are still in place . and concrete weights are not loose .
