The CC is provided to DISH (and all cable/satellite companies) by the network that creates the programming. Usually, live TV (like news, sports, etc) is the most jumbled because of the time it takes someone to transpose what is being spoken as it is being spoken. If this is a network that is available OTA (via antenna), verify that the issue is not happening when you are receiving the signal from somewhere other than DISH (if you cannot receive an OTA signal, try at a buddy's house that uses another cable provider). If the problem occurs via OTA or other providers, contact KIRO to have them improve their CC service. If it only happens when viewed with DISH, contact DISH, who will then resolve the issue with KIRO (usually a lag time in signal transmission from the provider).
SOURCE: Dish Network - Dish 500 Satellite 110 is not being recognized
You will need a DP or Legacy twin or quad, or DPP twin without using an external switch. If you use Legacy Duals, or DP Duals you will need a switch. USUALLY a SW21 is used to combine the signals but you may have a different one in use if at all.
The primary thing to remember when using a switch is that you must use the same type of LNB as switch e.g. Legacy switches with Legacy LNB's and Dish Pro switches with Dish Pro LNB's.
Check your LNB type. Legacy LNB's have only a Dish Network Logo on them, Dish Pro has DP on them and DPP have DP PLUS on them.
One of three things could be the cause:
1. Line of site. Must be clear of all obstructions to ensure adequate signal.
2. You have a faulty switch, or conflicting LNB and switch, or no switch at all.
3 you may have a bad port on the LNB.
As a fail safe check that your mount is level and plumb. You also may have the dish pointed directly at 119. Check the Skew and elevation settings as well. If LOS IS THE ISSUE YOU MAY NEED TO RELOCATE THE DISH OR REMOVE THE OBSTRUCTION.
In some extreme cases microwave towers and High Voltage lines also pose a problem but doubt this is the case for you.
SOURCE: Dish Vip211K receiver locks up on one channel
yes your signal is very good but it hangs up, the most important is the quality of your picture, cause signal is composed of so many impurities including noise, so dish be orientated once more.thanks.
SOURCE: How do I add another TV to Dish network. I simply
What you are looking for is called a mirrored location. Its a location that mirrors either tv1 or tv2. It can be installed using simply a few splitters depending on how you want it ran. If you do it your self it will save you alot of money. If not Dish Network will charge up to $99 for a reinstall
SOURCE: Need to Frequently Reset Dish Network HD VIP 612 Solo DVR.
When you bring up your guide look at the top of the screen and you will see the LIST: if this says ALL HD then press the guide button until you see ALL SUB or a menu and select ALL SUB. If your guide keeps changing by itself its possible to have remote interfence since you have a UHF remote, especially if you also see channel changes as well. Try setting the guide and go from there. If you still continue to have issues call 1-800-333-3474 for tech support for extensive troubleshooting or at dishnetwork .com/tech.
SOURCE: How do I get closed captioning on my 625 dish dvr....
Guest,
The 625 receiver does not have a setting to control closed caption. This is a setting from your TV itself. I would look at your TV manual to see how you can turn the feature on. I hope this helps.
Ray Calo
DISH Network
