If you want to connect and disconnect at your ease, the following steps will guide you through setting up a internet connection in windows using username and password whenever you connect.
Have a good time...
Step 1: Initial LAN Configuration
First connect all the equipments to your PC. Details about this is probably given on the manual
Now on windows go to control panel -> Network Connections
Select “Local Area Connection” and right click it . . .
Select Properties
Select TCP/IP in that box ->properties
Enter the details as follows
Set IP Address As 192.168.1.29
Subnet Mask As 255.255.255.0
Default Gateway As 192.168.1.1
Preferred DNS 208.67.222.222
Alternate DNS 208.67.222.220
Save settings and restart the computer.
Step 2: Settings for Modem
Make sure the Power LED, Link LED and USB/LAN LED are on/blinking
Open your browser (preferably Internet Explorer ) and goto http://192.168.1.1/
Input as follows
USERNAME : admin
PASSOWRD : admin
Now goto Setup Tab then click on new connection (left side navigation frame/panel)
Now fill the details as follows
Type : bridge
Sharing : disable
VLAN ID : 0
Priority Bits : 0
Encapsulation : LLC
Select LAN : LAN GROUP 1
PVC : new
VPI : 0
VCI : 35
Leave all others at default values Then click apply
The go to TOOLS tab
Click “system command” (left hand side)
Click “save all”
Apply and restart the modem.
Step 3: Setting up Internet Connection Dailer in windows
Now goto Control Panel->Network Connections
Create New connection (and a wizard will pop up)
Click Next
Connect to Internet(Select the radio button and click next)
Setup My connection Manually(select it and click next)
Connect using a broadband connection that requires a user name and password (select it and click next)
ISP name (type something, anything and click next)
Type in the User name and password given to you from BSNL in the specified columns (and click next)
If you want to add a shortcut of connection to desktop, check that square box and click finish.
Double Click the Icon in the desktop to connect to the BSNL Dataone broadband connection, and either double click the same icon or right click the system tray icon to disconnect from BSNL Dataone broadband connection.
Hope this will help you.
