Expert
- Posted on Feb 20, 2010
Re: Describe how to update blue ray player
Software Update Instructions
- WARNING!! Do not power off the Home Entertainment Server or disconnect it from the AC power outlet. Doing so may damage the Home Entertainment Server to the point of requiring repair.
- WARNING!! Do not press any buttons, except as instructed, until the update is complete. Doing so may damage the Home Entertainment Server to the point of requiring repair.
- The software update process usually takes about 15 to 30 minutes, depending on system configuration and network connection.
- Power on the television and make sure it is tuned to the inputs to which the HES-V1000 Home Entertainment Server is connected.
- Connect the LAN terminal on the HES-V1000 to your Internet source using an Ethernet cable.
- Power on the HES-V1000 Home Entertainment Server.
- Press "HOME" to go to the Home Menu.
- At the "Home" menu, select "Settings".
- At the "Settings" menu, select "System Settings" and then press "ENTER".
- At the "System Settings" screen, select "Software Update" and then press "ENTER".
- At the "Software Update" screen, select "Network Update" and then press "ENTER".
Note: The network connection display appears.
- Select "Yes" and press "ENTER".
Note: The server starts to check the version information.
- At the version confirmation screen, select "Yes" and then press "ENTER".
- The software License Agreement appears. After reading the content, select "Agree" and press "ENTER".
- The software update is downloaded and automatically starts updating the HES-V1000 software.While the software update is downloading:
- "DOWNLOADING XX%" appears on the front panel display, indicating the progress.
- If the download fails, an error message appears on the screen, and the display returns to the Home Menu.
When the software update is complete:
- "VERSION UP FINISH" appears on the front panel display, indicating that the update was successful.
- If "VERSION UP FAIL" appears on the front panel display, repeat the update procedure above.
- The system will power off automatically.
- Power on the Home Entertainment Server again.
Please refer the following link:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=5321&mdl=HESV1000
