Question about ASUS M2N-E SLi Motherboard
When I am on Skype my microphone works then doesn't work. It is a logitech webcam/microphone.
Posted by yikes99 on
Chris Hingee
  • ASUS Master
  • 32,281 Answers
I found this problem on my computer.
I had connected the Logitech into a USB hub then connected the hub to the computer's USB port. Then saved the configuration in Skype didn't work, every time I opened Skype I had to configure the microphone and video setting in Skype again.
The FIX. connected the Logitech direct into the computer's USB port and configured the Skype - Logitech microphone and video save settings. No more problems
Posted on Feb 11, 2010
I HAVE A NEW HP ALLIN 1 WIDOWS 8. ON FACEBOOK VIDEO CHAT THEY CAN HEAR ME, BUT I CAN'T HEAR THEM
Launch the Logitech QuickCam or Webcam software on your computer. Verify that you see yourself Logitech Webcam software window. Close the software window. Sign in to Skype. Click the "Tools" menu and select "Options." Click "Video Settings," check the "Enable Skype Video" and "Start my video automatically when I am in a call" boxes. Select your Logitech QuickCam from the drop-down list. Your webcam should display video in the window. Click "Audio Settings" if your QuickCam has a built-in microphone and select it from the microphone drop-down list. Check the "Let Skype adjust my audio settings" box in "Audio Settings" so Skype recognizes your microphone. Click "Save" to save the options for your audio and video settings. Skype will close the options menu.
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Microphone/speaker issues?
HI there go in call option in skype and make default your microphone from there. After that it will start work again. Thanks.
2helpful
2answers
I am not a computer person.I was wondering if logitech webcam C250h will work with skype?
Yes, I have a Logitech WEBcam (not the same model) and I use Skype.
After you installed Skype then :-
2helpful
On skype i can see the other person but they cannot see me, on test image is ok ?.
If the Logitech works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam
My camera quit working in skype, any suggestions in troubleshooting? the green light isnt coming on at all, it was working like 5 minutes ago
To test if the Logitech QuickCam is functioning, check the USB cable, make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
Skype doesn't read my camera
Before you can use your webcam in any chat program you have to configure it to that program
Start Skype.
On the Tools menu, click Options.
In the navigation pane of the Skype Options window, click Audio Settings.
Select your webcam as the default microphone. (If it has a built-in mic)
In the navigation pane of the Skype Options window, click Video Settings.
Select your webcam as the default.
Click Save.
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Camera is not working when on Skype but sound is?
There maybe a patch available with a later driver
Go to Device Manager, Expand 'Imaging' folder and right click on your webcam text. 'Update driver' and use internet option.
Check your webcam is set to default in Skype
  • Start Skype.
  • On the Tools menu, click Options.
  • In the navigation pane of the Skype Options window, click Audio Settings.
  • Select your logitech device as the default microphone. For example, select Logitech + model#.( if it has mic )
  • In the navigation pane of the Skype Options window, click Video Settings.
  • Select your Logitech device as the default Webcam. For example, select Logitech + model #
  • Click Save.
  • Failing that check if you have the latest version of Skype
    Disappearing Logitech mic pick
    I tried it again with the camera plugged in (duh) -- and the driver reappeared, the microphone works fine -- I successfully completed a Skype test call. I don't understand why it works that way, but now I know.
    ASUS M2N-E SLi Motherboard Logo
    Top ASUS Computers & Internet Experts
    Roy May
    Michael Thomas
    Michael Thomas
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
