Our Kitchenaid side by side KSCS25INSS01 fridge has a peculiar odor and taste to the water from the dispenser and the ice cubes. It almost has a refrigerant smell/taste. I have changed the filter on a very regular basis, even before the indicator suggests. The smell was so bad for awhile it permeated the entire fridge. We have cleaned the fridge thoroughly and removed anything that could be suspect. I changed the filter again just lately and it helped somewhat but the water still has the smell and taste but to a lesser degree now. Any help would be appreciated!
Check the condition of the teflon on the ice maker. You will probably need to replace the ice maker if the teflon is cracking and getting into your ice.
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
Ice storage bin needs to be emptied and washed.Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes. Interior of the refrigerator may need cleaning. Water chemicals. Installing an in-line filter can help with many odor/taste complaints. An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors. This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot. Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
You said, Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You
replaced the copper tubing which delivers the water to the fridge and
that didn't help. You replaced the copper tubing again with plastic
tubing...no better. Any suggestions? Your tap water doesn't taste this
bad.You bought a Kenmore french door fridge with water dispenser in the
door in July 2008. The fridge has a filter. A few weeks after the
fridge came the water and ice started tasting really bad, unlike any
bad water taste I have ever tasted. And your tap water is fine. The bad
taste appears to be random. Sometimes you get a cup full of nasty water
and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions! Did you do this before connecting the water line to your fridge? "Place the free end of the tubing in a container or sink, and turn ON the main water supply. Flush the tubing until water is clear. Turn OFF the shutoff valve on the water pipe. Coil the copper tubing."
Whirlpool remedy Off-taste, odor or gray color in the ice 1.Are the plumbing connections new, causing discolored or off-flavored ice? Discard the first few batches of ice. 2.Have the ice cubes been stored too long? Throw old ice away and make a new supply. 3.Does the freezer and ice storage bin need to be cleaned? See “Cleaning” or “Ice Maker and Storage Bin.” 4.Has food in the freezer or refrigerator been wrapped properly? Use airtight, moisture-proof packaging to help prevent odor transfer to stored food. 5.Does the water contain minerals (such as sulfur)? A filter may need to be installed to remove the minerals. 6. Is there a water filter installed on the refrigerator? Gray or dark discoloration in ice indicates that the water filtration system needs additional flushing. Run additional water through the water dispenser to flush the water filtration system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to 7 minutes initially). Discard discolored ice. Let me know what works, Thank You , HUUUM!!
Since I found that the water itself being fed to the trays and being dispensed was bad. I replacethe nylon, reinforced plastice icemaker hose with 1/4" copper supply line. That, along with purging the hopper (getting rid of) any old ice as well as washing the hopper out real good and giving the freezer a general cleaning - seemed to do the trick. No repugnant odor or taste. (I didn't even replace the filter- the cycle is every 6 mos.)
Hope this helps others who may be experiencing this same prob with this type of side by side appliance.
