Maytag Atlantis MDE7400AY Electric Dryer Logo
Posted on Feb 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No heat turns on but no heat
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Dec 08, 2010
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10844194
Points
101584
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Honeywell Thermostat RTH230B does not call for heat
It sounds like it's wired correctly given you can operated it manually. Is this a new thermostat? Has the program function ever worked? Ensure you have the current date/time including am/pm set properly so the program understands it's starting point. If that's not the issue try setting your temperature set points to extremes. If that enables your HVAC to react it means your temperature sensor is failing.
1988 mallard sprinter travel trailer electric heat, how do I use it
To use the electric heat on your 1988 Mallard Sprinter travel trailer, you will need to follow the instructions for your specific Duo Therm Brisk Air unit. Here are the general steps you can follow to use the electric heat:
  1. Set the thermostat: Set the thermostat to the desired temperature. The thermostat controls the electric heat and determines when it will turn on and off.
  2. Turn on the electric heat: The electric heat on your travel trailer is usually controlled by a switch or a button on the thermostat or on the unit itself. Turn on the electric heat by flipping the switch or pressing the button.
  3. Adjust the temperature: Use the thermostat to adjust the temperature as needed. The electric heat will turn on and off as needed to maintain the desired temperature.
  4. Turn off the electric heat: When you are finished using the electric heat, turn it off by flipping the switch or pressing the button.
If you are having difficulty using the electric heat or are unsure about how to operate your specific Duo Therm Brisk Air unit, you may want to refer to the owner's manual or contact the manufacturer for assistance. They will be able to provide you with specific instructions for your unit and help you troubleshoot any issues you may be experiencing.
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Having heat issues with my Ge Heat/air combo unit. The air works fine but when I go to heat only the secondary heating coil comes on but the heat pump doesn't engage! I had a tech look at it and he le
Is it wired as a heat pump? Does the tstat know it's a heat pump? Turn power off, unhook all wires from tstat, TAKE PICTURE FIRST!!! Wire red yellow green and orange together and turn power on. See what happens. Turn power off, remove the orange from the bunch and turn power on. See what happens. Let us know!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
No heat turned on but no heat coming out
Try turning on the heat and see if heat comes out? If you turn on the heat and cold air blows you may have a bad heater core. More than likely a repair shop would need to fix it.
Furnace switches to auxiliary heat while in cool
It's likely a bad tstat. Turn the power off to your air handler. Remove red , green, yellow and orange wires inside the tstat and wire nut them together. Not sure if your reversing valve energizes in heating or cooling but, turn the power back on. If the unit is heating turn the power off and remove just the orange wire and turn power back on. Let this run and see if it you are ONLY getting cool air ALL the time. If so you have a bad stat. If still getting heat possibly you have a bad control board in the air handler. Good Luck!!
What does the "auxillary heat"
Auxiliary Heat is used to turn the electric heat strips ON, If the heat pump is not working. Or if the heat pump can't bring the space temperature up to Set Temperature it will display Aux Heat ON....... Assuming you have a Heat Pump System with Auxiliary Electric Heat as Back up...... If the tech didn't install a jumper wire from AUX to W on the subase which is in back of the Display on the Thermostat.....you won't get Auxiliary Heat if the Thermostat is set for Auxiliary Heat. Other wise the thermostat will turn the heat pump on first and then the electric heat (Aux Heat) if it needs it to satisfy the set temperature....... Hope this helps
2answers
I just turned on our heat unit "FA4A AC/Heat Pump"
There probably isn't a reset button=magic fix. With it in heat pump mode and tstat set above indoor temp, check your outdoor unit to see if it's operating. If not, check all breakers to it. Can you see any ice accumulated on the outdoor unit? If it is running and not producing heat, turn the tstat to emergency/auxiliary heat. and the heat pump turned off to prevent damage. You'll need a service tech.
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
