Freezers Logo
Posted on Feb 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Kenmore Upright Freezer. I need to
I have a Kenmore Upright Freezer. I need to deFrost it. It is about 8/9 years old, cannot find Owners Man. What is best way to defrost it, Has hole in bottom.
  • Charles T Nevin
    Charles T Nevin May 11, 2010
    Take everything out and put in another freezer or ice chest with out ice. This is a good time to clean out the old stuff. If the hole in the bottom can be used to catch the water you can put a pan or tray to catch it. You can place pans in the bottom to catch the water just keep checking them to prevent overflow. You can put a small fan blowing into the freezer to speed it up or even use a hairdryer. DON'T USE ANYTHING TO CHIP AT THE ICE. WAIT ON IT TO MELT. It will damage the coils etc.
Dan Webster
Level 3:
  • Master 8,221 Answers
  • Posted on Feb 10, 2010
Dan Webster
Master
Level 3:
Answers
8221
Questions
5
Helped
2379106
Points
25840
I unplug mine and let it take several days. You break a line or punch a hole in a line and the freezer will be ruined. Just let it thaw out on its own to prevent damage.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Ice build up in the bottom of my upright freezer
If it's a frost free model, it could be caused by a plugged defrost drain. Every time it goes through a defrost cycle the water is supposed to drain into the compressor compartment. You can defrost it by unplugging it for a day or two and then remove the panel covering the evaporator coil. You should be able to see the drain tray under the coil and find out whats blocking it.
1helpful
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Defrosting
Hi, Is the compressor running? How old is it? Is the compressor clicking off and on like it is trying to start but can't?
I want to try ans help, just need some answers.
Vic
Need correct setting for 30 yr old upright Kenmore freezer
Your best bet is to start in the middle. Guesstimate and let it run. The test is to see if water freezes solid in 6-8 hours. If not, you can turn about 1/4 turn or less. Then you can try hamburger meat which a lower freezing temp and see if it gets solid. Your perishable items should be put somewhere else until you are ready. At least the water frozen will keep the meat safe from bacteria growth or spoilage. Let me know how you do.
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
sounds like you have compressor lockup-mike
1helpful
Freezer motor has burning smell
disconnect from mains. take cover off compressor electrics. check starting device - easy to replace
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
