Question about Canon imageCLASS MF8180C All-In-One Laser Printer
E-000 ON THE MF8170 WONT RESET, IS IT THE FUSER UNIT?
brett207
  • 231 Answers
Yes, it is a fuser error.
Posted on Feb 11, 2010
Testimonial: "Great Thanks'"
How do i change sleve of hp 2300dn ?
the sleeve you are referring to is the Teflon sleeve located in the fuser unit and is covers the upper heating element in the fuser unit.. unless you are familiar with fuser rebuilds don't attempt it.. you can purchase rebuilt fuser units or brand new OEM units From Precision Roller Part number is RM1-0354-050,or RM1-0354-000
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Apr 24, 2014 | HP LaserJet Office Equipment & Supplies
Samsung printers
This error is a fuser malfunction. You will need to replace the fuser unit in order to get this running again. A fuser unit will run about $90 for a refurbished unit. You should check the manual for more error codes: Samsung SCX 5635FN Manual
Mar 27, 2014 | Samsung SCX-5635FN All-In-One Laser...
If problem persist contact dealer or service rep turn the main power on e301-0001
This is a fuser error, the fuser replacement for this machine is best done by a technician as there is moderate disassembly involved..
Your local canon warranty agent will be a good place to start.
This same printer engine is used in a few HP printers and multifunctions and the fuser is available from HP as well. Though HP are usually slightly dearer.
If you want to have a go yourself the part number is one of the following, depending on your electrical grid voltage un your part of the world
Canon imageCLASS MF4450 Fuser (Fixing) Unit - 120 Volt
RM1-7576-000
or
Canon imageCLASS MF4450 Fuser (Fixing) Unit - 230 Volt
RM1-7577-000
Oct 26, 2013 | Canon ImageCLASS MF4450
I have bizhub c250 and the 83000 prints (copies). My Fuser unit show empty and I can't use my bizhub c250. it should be replaced on 120 000 copies. How to reset this fuser unit on my printer?
You can reset the fuser counter only by replacing the counter reset fuse. This fuse is located on the fusing unit which must be removed and a small cover opened to get access to the fuse. You ca get the fuses from precisionroller.com
Their part number is M9970. It will say imaging unit fuse but the fuse is the same for the C250 fuser reset.
If you do not feel that you can remove the fusing unit and replace the fuse then you might be able to find a local independant copier repair person to do it.
Be assured tho that you can reset this indicator as I have done this a dozen times or more for my customers.
Good Luck and Thank You for using Fixya.
Nov 04, 2010 | Office Equipment & Supplies
My machine have a mensage e 000, need your help
A E000, means that you have a problem with the fuser unit. You can try to leave the copier uluged for a few minutes. If you plug it back in and it codes out again, you will need to replace the upper fuser unit or the whole fuser unit. Good Luck
Oct 10, 2010 | Canon ImageRUNNER 1670F Copier
What cause errer 000 canon np7161.when lit, it is E000 and it goes off after a few seconds.
A error code of E000 means that the fuser unit is not turning "ON" or is not warming up correctly. You will need to fix the problem before you can reset it. You may have a blown fuser lamp or thirmister or thermal fuse or all three? Good Luck
Oct 03, 2010 | Office Equipment & Supplies
System error 000
A E000 means that the fuser unit is not heating up correctly. You will most likey need a new fuser unit. If you unplug the copier and plug it back in and it will not come to "Ready" you need a new fuser. Good Luck
Jul 23, 2010 | Canon imageCLASS D761 Copier
Fuser film has split so looking for part number of fuser film or fuser assy of canon L100 fax machine
FM2-3967-000 FIXING ***'Y FOR 120V, and
FM2-3968-000 FIXING ***'Y FOR 230V.
Best way is to replace whole unit, because of pressure, bushings,...
Jun 04, 2010 | Canon Office Equipment & Supplies
Kode erorr e0000-000
This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
May 15, 2010 | Canon imageRUNNER 5000 Copier
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
405 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
