Makes the noise with or withour clothes in it. I took the back off to see if I could see anything. Everything is sound as far as I can see. When I put the washer into a spin cycle it sounds like something is trapped between the washer basket and the drum.Makes the noise with or withour clothes in it. I took the back off to see if I could see anything. Everything is sound as far as I can see. When I put the washer into a spin cycle it sounds like something is trapped between the washer basket and the drum.
You can't post conmments that contain an email address.
The only other thing that cause's this would be a broken spring which keeps the tub stable or a broken gear inside the transmissionThe only other thing that cause's this would be a broken spring which keeps the tub stable or a broken gear inside the transmission
The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on the upper hose hitting the top cover ir a plastic injector mold standoff on the outer tub bearing housing, also a flat spot in the belt could cause a tapping noise. Something between the outer tub and wash basket. I have had to remove items lodged in the drain tube between the pump and tub, like bra under wires. Sometimes you can squeeze the tube and feel objects the ate lodged. I always take the tube off the tub side and run my finger all the way down to the pump impeller to make sure. I also check the I can spin the impeller and the nothing is in the pump. Hard to say with out being there. Where do you think the noise is coming from top , bottom , left , or right side?
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
