Question about Hotpoint HSS25GFP Side by Side Refrigerator
Outside walls of freezer feel hot to the touch
Posted by marvman9 on
Charles T Nevin
  • 4,070 Answers
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Also clean the condenser coils on the back.
Posted on Feb 10, 2010
Freezer door is very hot to the touch on the outside
Hello, their are heat coils in the doors, their maybe a issue with the door heat circuit controls.
Mar 18, 2014 | True 72 cu. ft. / 2039 liter Commercial...
Freezer is hot on the sides is this normal?
Good day,
Yes, that is normal. It is ideal to not be in a hot room but as it reaches temperature and begins to cycle off and on it will become somewhat cooler.
Jul 20, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
Walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
Sep 08, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Outside wall on freezer side is hot to the touch
clean your condenser coils under the frig,your over working with dirty coils and it is over heating-mike
Oct 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
My freezer is hot!
It is normal for the freezer or fridge walls to be hot sometimes, some important points are to make sure that there is enough ventillation around the fridge/freezer, especcially the back, so that air can circulate around it freely. Also maybe just check that there hasn't been anything fallen down the back blocking the vent, and that there isn't a dust collection or anything. Otherwise as far as I know this is normal.
Aug 19, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Freezer problem
if you don't hear it running for extended periods of time (more than 15 minutes) without stopping, and if it does not immediately re-start once it does stop, and if it is extremely hot climate outside (85 F and above), then yes, this is acceptable.
Jun 08, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
170 people viewed this question
Top Hotpoint Refrigerators Experts
jdthefixer
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
