Question about Samsung NC10-14GW PC Notebook
Mouse Pad freezes
My mouse pad cursor stops in it's tracks periodically whilst I am trying to use it, just freezes for no reason, and a circle appears over the cursor, then suddenly I can move the cursor again. Happens a lot on my brand new Samsung NC10.
  • Anonymous Feb 10, 2010
    Thank you for your help, but not quite sure what you mean? Press FN+ OR? Can you please elaborate.
RAJDEEP DUTTA
  • Samsung Master
  • 2,517 Answers
Will you please try these.
FN+ Following marked ker.
Mouse Pad freezes - 36a19f7.jpg Thanks & waiting for your feed back.
Posted on Feb 10, 2010
  • RAJDEEP DUTTA
    RAJDEEP DUTTA Feb 10, 2010
    Hi hope you see the image here. There is few keys which is maked in different color. Some one of them marked as per my picture. Thats look like a touchpad symbol on top of the key. So when you confirmed about it then press FN+ thats key.Usally FN+F8 key used to with samsung.
My cursor disappeared on my Samsung 303C12. Is there a way to turn the cursor on and off?
It sounds like you turned off your track pad. On some laptops there is an indentation on the pad to turn on and off and some have buttons on the laptop. Did you go into your track pad properties to see if it is on? You can do this by clicking on the mouse on the lower left corner of your laptop or by going into control panel. I hope this helps.
Sep 16, 2014 | Computers & Internet
Mouse touch pad not working
Try to Upgrade your Mouse Pad driver.
Your problem would be solved by doing so.
I have faced the same problem. I did upgrade Mouse Pad driver and Yes my mouse pad working fine.
Apr 24, 2013 | HP EliteBook 6930p Notebook PC
Cursor freezing
Hi
It could be trouble with Motherboard or the chip under the track pad.
Try to re-install the mouse driver. and try to check.
In case if you have any trouble then do contact us here in Fixya.
Thank you
Aug 11, 2012 | Advent Computers & Internet
My computer comes on opens windows all looks ok as soon as i touch the cursor, nothing responds,
Make sure that the track-pad (mouse-pad) is not disabled. There should be a button located above the track-pad that allows you to disable or enable the track-pad. If not, I would use a USB mouse and then go into the Control Panel, mouse and change settings there to enable the track-pad.
Nov 08, 2010 | Acer Aspire 4720 Notebook
Sir, i want to know about the optical mouse in detail. what is the important point of it to use. thanks, tin
Optical mouse was developed by Agilent Technologies and introduced to the world in late 1999, the optical mouse actually uses a tiny camera to take 1,500 pictures every second. Able to work on almost any surface, the mouse has a small, red light-emitting diode (LED) that bounces light off that surface onto a complimentary metal-oxide semiconductor (CMOS) sensor.
The CMOS sensor sends each image to a digital signal processor (DSP) for analysis. The DSP, operating at 18 MIPS (million instructions per second), is able to detect patterns in the images and see how those patterns have moved since the previous image. Based on the change in patterns over a sequence of images, the DSP determines how far the mouse has moved and sends the corresponding coordinates to the computer. The computer moves the cursor on the screen based on the coordinates received from the mouse. This happens hundreds of times each second, making the cursor appear to move very smoothly.
Optical mice have several benefits over wheeled mice:
No moving parts means less wear and a lower chance of failure.
There's no way for dirt to get inside the mouse and interfere with the tracking sensors.
Increased tracking resolution means smoother response.
They don't require a special surface, such as a mouse pad.
Although LED-based optical mice are fairly recent, another type of optical mouse has been around for over a decade. The original optical-mouse technology bounced a focused beam of light off a highly-reflective mouse pad onto a sensor. The mouse pad had a grid of dark lines. Each time the mouse was moved, the beam of light was interrupted by the grid. Whenever the light was interrupted, the sensor sent a signal to the computer and the cursor moved a corresponding amount. This kind of optical mouse was difficult to use, requiring that you hold it at precisely the right angle to ensure that the light beam and sensor aligned. Also, damage to or loss of the mouse pad rendered the mouse useless until a replacement pad was purchased. Today's LED-based optical mice are far more user-friendly and reliable.
Thanks and regards,
Anil.B.R
Aug 18, 2010 | Computers & Internet
Mouse cursor moves by itself
two reasons : 1> your mouse is extra sensitive, go to control pannels and then mouse and lessen the speen of ur pointer. 2> you're using some cloth or some soft area as ur mouse pad, such things slip easily, try using a proper MOUSE PAD
Feb 08, 2010 | Dell Optical USB Mouse opmse-5
Track pad is not working...when i point cursor, does not click in
Try going into your mouse settings and make they are turned on. If you have the Sympnatics touch pad you have the option to turn it on/off. Does it work with an external mouse (USB mouse) if so its probably turned off.
Jan 14, 2010 | Gateway 450ROG Notebook
When typing the curser jumps to a different position
This is because you are touching the touch pad with your palms. when typing avoid contact with the mouse pad in your laptop. I hope this will help. Thanks.. Please rate this!!
Aug 16, 2009 | Acer Computers & Internet
How can I stop my curser from jumping around whilst typing ?
Hello
Most probably because your 'Touch Pad Mouse' is touched by your palm (hand or something) while you are typing. Avoid contact with the mouse touch pad while typing.
Option 2:
If you have a centre moveable mouse on your laptop, start using it and disable the 'Touch pad mouse'
Best of luck!
Jul 23, 2008 | Acer Aspire 5100 Notebook
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Samsung NC10-14GW  PC Notebook Logo
Top Samsung Computers & Internet Experts
Jean Thiebaux
Jax Planet
Jax Planet
aliasger yq
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
