Question about Linksys Wireless-G Broadband Router
I'm trying to hookup a usb modem broadband to a router for a desktop and laptop
Posted by peg460 on
Jeffrey Pedimonte
  • 298 Answers
This wireless router does not have any USB connection on it. Types of connection available on this router are wireless and Ethernet. You can check on the modem if there is an Ethernet port on it.
If your modem has an Ethernet port, I recommend that you test the Ethernet connection using one of your computers. We want to make sure that the Ethernet connection on the modem is enabled. If not, you may need to contact your ISP or the modem manufacturer to make sure that the Ethernet will work before you install the router.
If your modem does not have have an Ethernet port on it. This is not the router that will do the work for you. And I personally does not seen any router yet with the USB port for the modem.
Posted on Feb 21, 2010
Broadband vs Dial up.
you need either a wireless usb adapter... and a wireless router or a usb router and a usb cable...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 27, 2009 | Dell Latitude C610 Notebook
Broadband connection
You should find the manual that comes with the Router. It will have good instructions on the details to configure this.
Basically you will use your browser on your desktop to connect to a web page within your nb504 router.
You will turn on wireless connections and enable security plus give your wireless network a name.
Once that is done you will configure security on your laptop to connect to your wireless network.
Don't skip the security bit or your neighbors will be able to use your internet connection for free.
The default settings in modem devices are really good these days so follow the recommendations in your router manual and you should be able to figure it out.
If you can't find your router manual you should be able to download it from Netcomm.
Hope this helps
Jul 11, 2009 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
Compaq armada v300
If you have a router on your broadband, you need a RJ45 network cable - right next to the modem port on your laptop is a network port - this will use the correct cables you need to connect to your router.
If you don't have a router but only a broadband modem, just connect it to the USB port on your laptop, install the software and you should be good to go.
Feb 08, 2009 | Compaq Armada E500 Notebook
USB Broadband to wireless router through desktop PC
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
PC1:
IP: 192.168.0.2
Network mask:255.255.255.0
PC2:
IP: 192.168.0.3
Network mask: 255.255.255.0
Default gateway: 192.168.0.2
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Regards
Imre
Nov 26, 2008 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
Wireless Network working on laptop, lost internet on desktop.
If you disconnect the desktop from the modem, were you able to get an Internet connection in your laptop?
In order to get Internet connectivity on your desktop at the same time with the laptop, then the desktop needs to be connected to the router. It should be connected to one of the Ethernet ports at the back of the router. Since, your desktop doesn't have an Ethernet port, then you need to connect a USB to Ethernet adapter to your desktop. Then from that adapter, you will connect to it an Ethernet cable going to the router.
You may check the following models:
Linksys USB200M
Linksys USB100TX
Belkin Gigabit USB 2.0 Network Adapter(F5D5055)
D-Link DUB-E100
There are other brands that offer USB to Ethernet adapters that you can check.
Hope this helps!
Nov 22, 2008 | Linksys Wireless-G Broadband Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Belkin wireless problem
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Aug 12, 2008 | Belkin (F5D9230-4) Wireless Router...
Connecting desktop and laptop to a wireless router
I have the same problem. Startign this morning, when I connect modem directly to desktop, it works. But when I connect modem to this router and then connect to desktop, nothings works.
again - if connect modem back to desktop directly, then it works!.
what is the issue.....? not able to figure it out.
I did reset, change router IP etc etc everything nothing resolves the core issue!
Jul 19, 2008 | Linksys Wireless-G Broadband Router
WIFI
You can go for a wireless router, so that you can access internet anywhere in your house, ,
Jul 18, 2008 | Dell Inspiron 5100 Laptop
WRT54G Router Hookup
All you need to do is connect the modem to the router. From the router, you will want a computer connected to it so you can configure your wireless network.
May 28, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
208 people viewed this question
Top Linksys Computers & Internet Experts
Mike
Jeffrey Groves
Jeffrey Groves
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
