Question about LG 42LC2D 42 in. LCD HDTV
My 20 inch lg tv crt monitor will not show a
My 20 inch lg tv crt monitor, will not show a picture i changed tv tuner but picture not shown pls. some one tell me which component i can change?
  • 666 Answers
Is video show on vcr player? if yes you need to replace jungle ic which is switching line from tv tuner to line in video.
Posted on Apr 04, 2010
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
Sound ok but no picture
see the b. diagram and test the power supply ;transistor, fuse, filter, switch, c.breaker rectifier,IC regulator voltage.
measure the horizontal output =125vdc
all other circuit:12vdc
color:12vdc
Oct 17, 2012 | JVC Televison & Video
My LG 700E crt monitor has stop functining to control brightness and contrast ,Any other way to increase or decrease brightness and contrast. pls let me know thanks
It's time to RESPONSIBLY RECYCLE any 17-inch CRT monitor, and buy a LCD monitor;
used LCD monitors can be purchased for under $50.
It would cost you over $50 to take the CRT to a TV/Video repair shop, for trouble-shooting and repair.
May 11, 2011 | LG Studioworks 700S 17" CRT Monitor
I have ODYSSEY external tv tuner which is connected to 20" inch HP LCD monitor. for six month ther was no probelm but now we are not able to view the Video but audio we can listen from the TV tuner. There...
Either the line connection (cord) is poorly making contact, or the video in/out module is bad. Attach the tuner to another computer monitor and see if you obtain a signal. If so you know the problem is with the HP LCD.
Feb 03, 2018 | Televison & Video
My lg 14 inch crt desktop monitor pictue become
The CRT has screen adjustments, there is a screen adjustment button on the monitor that will allow you to adjust the width of the image as well as the height etc.
Jan 21, 2010 | LG Studioworks 775N 17" CRT Monitor
MY SHARP 20 INCH COLOR TV GIVING NOISE IN SOUND?
your A.F.T. COIL ADJ AND SOLVE THIS PROBLEM
Jan 16, 2009 | Televison & Video
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on [email protected]
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
LG 42LC2D 42 in. LCD HDTV Logo
317 people viewed this question
Ekse
RONALD CARTER JR
