After approx. 25000 pages you should replace drum unit
This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions below:
Open the front cover.
Press the Clear/Back key.
Press 1 to reset.
Close the front cover, pressing firmly on each side until they click into place.
Normal
0
Driver could be corrupt. Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
