Question about HP Computers & Internet
Durin start display stays black and one long beep
During startup display stays black and one long beep and two short beeps are hearing
Posted by mustpets on
  • Anonymous May 11, 2010
    Hi Please can you advise what PC/Motherboard you have as all Motherboard beep codes are different Please can you also ensure that you do not have any external USB flash drives plugged in when booting up Please leave feedback/vote if my answer was helpful
Martin Shaw
    Novelist:
  • 157 Answers
Hello mustpets,
If it's an Award bios: 1 long, 2 short beeps indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
*Please see this related web link:
http://www.pcguide.com/ts/x/sys/beep/awardB12-c.html
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Posted on Feb 10, 2010
Anonymous
    New Friend:
  • 25 Answers
Based on the information provided, looks like some peripheral or component failed. This abnormal beep means some components (like RAM) is either not functioning OR is loosely connected etc.
If you are comfortable with your desktop, i would suggest >> (1) checking if the RAM modules are inserted properly or not. (2) Checking if the Video card is inserted properly.
Sometimes RAM/video card etc get loose due to a shock/**** etc, and hence the abnormal beeps.
If you are not comfortable with opening your desktop, then i am afraid you would have to call for service to check whats wrong in the system.
Thanks and do tell if this solved your problem.
Why does my notebook samsung np-nc10 beep on startup?
some laptops and desk tops beep on start up.but some beep when it has ram problems.
May 06, 2014 | Samsung NP-NC10-WAS1US Notebook
3 beeps on startup
Below are IBM BIOS Beep codes that can occur. However, because of the wide variety of models shipping with this BIOS, the beep codes may vary. Beep Code Description Document No Beeps No Power, Loose Card, or Short. CH000312 1 Short Beep Normal POST, computer is ok. No problem 2 Short Beep POST error, review screen for error code. See screen Continuous Beep No Power, Loose Card, or Short. CH000607 Repeating Short Beep No Power, Loose Card, or Short. CH000607 One Long and one Short Beep Motherboard issue. CH000607 One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. CH000607 One Long and Three Short Beeps. Video (EGA) Display Circuitry. CH000607 Three Long Beeps Keyboard / Keyboard card error. CH000304 One Beep, Blank or Incorrect Display Video Display Circuitry. CH000607
Mar 26, 2013 | IBM ThinkPad Computers & Internet
My dell PP08L beep 2 times during startup\
Dear Micheal Jorstad
Look for Ram bank and remove Ram,clean it and clean the bank then put it back and turn on your lap.
Best Regards
Mazagange
Mar 23, 2013 | Dell Computers & Internet
There's a sound during startup
There is no problem with your computer. It's just natural to have a beeping sound during start up. If there is, then it will show an error message in the screen.
If it's just a short beep, then it's normal.
Carlo
Jan 23, 2013 | LG X130 Netbook
System board security chip
http://en.community.dell.com/support-forums/desktop/f/3514/p/19348729/19758657.aspx
Oct 19, 2012 | IBM ThinkPad T42 Notebook
On startup there is 4 beeps then 2 then nothing. The laptop belongs to my grandouther.the power coard was frade,so my guess is that's where the problem started.
Beep codes are used by the BIOS during the POST to report certain initial system errors.
If you're hearing beep codes after you turn your computer on, it typically means that the system has encountered some kind of problem before it was able to display any kind of error information on the monitor.
Follow the steps below to determine what system problem the beep code is representing.
Difficulty: Average Time Required: Anywhere from 10 minutes to a few hours depending on the cause of the beep code Here's How:
  1. Power on the computer or restart it if it's already on.
  2. Listen very carefully to the beep codes that sound when the computer begins to boot.
    Restart your computer if you need to hear the beeping again. You're not likely to make whatever problem you have worse by restarting a few times.
  3. Write down, in whatever way makes sense to you, how the beeps sound.
    Important: Pay close attention to the number of beeps, if the beeps are long or short and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
    This is all important information that will help determine what issue the beep codes are representing.
  4. What steps you take to solve a particular beep code will differ depending on the BIOS manufacturer.
    Choose the correct beep code troubleshooting guide below based on your motherboard's BIOS manufacturer:
    Tip: Not sure what brand of BIOS is on your motherboard? See this How to Determine Your Motherboard BIOS Manufacturer guide for some helpful advice.
Aug 07, 2011 | Everex StepNote® VA4103M PC Notebook
My Acer Veriton L410 gives a short beep at startup. How do I disable it or turn it off?
depending on ur virus scanner, it could be searching for viruses during start up
Sep 29, 2009 | Acer Veriton L410-ED4450C PC Desktop
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
2 short beeps at startup
Two beeps is an indication of a memory problem. Try re-seating the RAM, you may need to replace one or more of the memory modules.
Re-seating is the first thing to try.
Good luck with this.
Mar 24, 2009 | Everex StepNote NC1500 Notebook
Computers & Internet Logo
232 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
