Sony Cyber-shot DSC-W130 Digital Camera Logo
Posted on Feb 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony syber shot w130 10 min limit for movie clip
Hi i have a sony syber shot w130
but it has 10 minute limit for movie clip.how can i remove that limit?
Glyn Kendall
Level 2:
  • Expert 146 Answers
  • Posted on Feb 10, 2010
Glyn Kendall
Expert
Level 2:
Answers
146
Questions
0
Helped
53119
Points
435
You can not remove the 10 minute limit.
The manual says that 10 minutes is the maximum time you can shoot continuosly.
You can make a longer movie if you break the shots up to less than 10 minutes each.
Hope this helps.
2answers
HOW DO YOU EXTEND THE FILMING LENGHTH IN A fUJIFILM FINEPIX S3380 CAMERA
The S3380 is a still camera with limited video capabilities, not a true video camera. No matter how big the memory card, a single movie clip cannot exceed nine minutes.
This limitation is due to economics, not technical. In some countries video cameras are taxed at a higher rate than still cameras. A still camera that cannot record for ten minutes is considered to be a still camera, not a movie camera, and is thus taxed at the lower rate.
How often do you see something in a movie lasting ten minutes, shot continuously from the same viewpoint with the same camera? Usually movies are made by splicing together shorter clips.
If you really need to be able to film longer clips, like a family member performing in a play or a concert, then you need a true video camera.
Oct 19, 2014 • Cameras
1helpful
My camera Samsung ST76 is recording for only 20 minutes even though there is lots of space available
The camera limits the maximum length of a single HD clip to 20 minutes. In some parts of the world video cameras are taxed at a higher rate than still cameras, where "video camera" is defined as a camera that can record longer than 20 minutes in a single clip. By limiting the recording to 20 minutes or less the camera can be priced lower.
When was the last time you saw a movie with a single shot that lasted longer than 20 minutes? Movies are almost always comprised of shorter clips edited together.
Expand video duration ?
You should be able to record up to about 30 minutes in a single clip, assuming your memory card is large enough. A 16GB card will hold about an hour of full HD video or over 40 hours at the lowest resolution.
The 30 minute limit is on the length of a single clip. You can stop one clip and then start a new one. How often do you see a single continuous clip lasting more than a few minutes in a Hollywood movie?
Where can i find a free manual for my Sony Syber-shot DSC-P30?
You can download and print the instruction manual in PDF format by clicking this link:
http://www.docs.sony.com/release/DSCP30.pdf
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Memory Stick is empty and when I turn on my Sony Syber-Shot DSC-P73 Digital Camera its telling me Memory Stick Error and I don't know why?
that happens due to contact/virus ,so formate the card.Clean the contacts of the card/card reader of the camers,if needs chaque the proper connections .
My sony syber-shot 12.1 downloads pictures but not the videos please help.
Use a separate card reader..it will download your videos to a folder you create on your desktop.
I have a sony syber shot camera optical zoom 3x. sony DSC-T1. When I turn it on, the screen says ''Rec. folder is 101MSDCF'' The screen is black. I can take a picture but nothing appears. What can be my...
How about turn the nobe on the top. It is on the movie part. so it is recording movie. Change it to P or some other letter. You should be able to take picture now. good luck
1helpful
DSC-W120 Sony. Movie record time frame
I'm afraid that Sony did not think that this was an important feature. The camera is inherently limited to ~10 minutes. There's nothing you can do to make this happen. See this page from Sony (it's a google cached version because the actual Sony page was down when I checked). Scroll down to where it says "MPEG Movie VX Fine Mode"
Sony cyber shot t9 slide show music turn off
When I turn my Syber shot 6.0 mega pixels on it shows only a white or dark display. The fotos taken are the same. It seems that something is not opening the lens. What is the problem and how can I fix it?
Many thanks.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
