Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
My flat screen hd sharp aquos color turns green when we are watching it. it is only 3 three years old. what can this be? thanks
Posted by mannunziato on
Anonymous
    New Friend:
I'm not sure if this is the same, but people were green no matter how i adjusted the tint, and lacked overall color. I doubled checked the component cables, taking each one out, and putting it back firmly,
Picture is back to normal. Easy fix.
Posted on May 12, 2010
Carmen West
My sharp arquos is a bit over 3 yrs old the screen turned green and it wont turn on. What should I do?
Posted on Oct 01, 2018
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Sharp Aquos has distorted colors
The set should be transported upright but that rarely causes these issues-----suspect either main signal board or also possible is the power supply (for voltages changing when set is on).
Also if set was opened look for all plugs to be seated--ones with cloth tape where they connect look at first.
failing that based on age of set consider having a technician look at it or if over 3 years consider a new set with extended warranty--70% of this type of set in our shop (100 plus sets at any time in for repair) are less than 3 years old.
Oct 29, 2012 | Sharp AQUOS LC-42D43U 42" HDTV LCD TV
I have a Aquos Sharp HDTV Model LC-32D62U that is a liittle over two years old. I am experiencing a Green Sceen when switching back & forth between channels. The only way to clear the Green Screen is...
that is the TV reading the HD signal and basically telling itself to allow the HD signal. When that happens there is a flicker of green, or sometimes the screen goes black. It is annoying, but its not just your TV, its pretty much on all tvs. This won't be a problem once everything is HD.
Nov 26, 2010 | Sharp LC32D62U 32 in. LCD HDTV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No picture -- white screen -- no sound
With no video and the the colored stripes, it sounds like the LVDS cable needs to be reconnected to the LCD control board or the control board itself is bad. If the unit is only 3-4 months old, it should be covered by warranty
Nov 18, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
LCDTV - Picture problem
Do the lines only appear on the Cable box input? It maybe be a problem with your cable. Try to isolate the problem.
Do you see the lines on all sources such as your DVD player as well? If you press the MENU button on the Sharp remote, do the lines go through the menu as well? If yes, it is most likely a TV problem.
A bunch of lines sounds like it is most likely a problem with the connection with the LVDS cable, if not that, then a defective main board.
There isn't really much you can do about it now.
Since the TV is less than a year old, I suggest calling Sharp to locate a local authorized service center.
Mar 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture quality
I think you are right about the backlight. You need to replace the backlight tube or, if you can, replace the TV. Good Luck.
Sep 13, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
Top Sharp Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
