Question about Lorex 4 Channel Business & Home Security Digital Video Recorder with 80GB Hard Drive
I am getting error code 8 after it sees the hard drive on a digimerge dht 304. What is it and how can I fix this ?
1helpful
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
How do reset the adminitrator password?
What OS are you using? You need to specify if Windows XP, Vista, 7 or 8.
How do I fix a Digimerge security system keeps blinking and beeping and wont record?
Your hard drive might be defective and the beeping alarm is the warning that there is no device to record on.
How do I fix my digimerge dvr problems?
You have an issue with your hard drive.
2answers
Error 1407 external drive
That's a Mac error stating that the file you are trying to delete is currently being accessed.
First, close all open programs and try to delete the file. If that doesn't work, eject the drive by clicking the eject button in a Finder window. Disconnect the drive. Reboot. Then reattach the drive and immediately delete the file.
Disc for digimerge model number dhu516251
http://www.digimerge.com/wp-content/uploads/2011/06/DigiClient-v2.14.11-for-the-DHU500R-Series.zip
The digimerge website has the download info under "discontinued" tab. This link will get it installed on your laptop for you.
1helpful
I have an error code of BIOHD-8, what does this mean and can it be fixed?
BIOHD-8 is a SMART drive error code. It's issued when SMART thinks your drive is failing. Doing some research it seems that there have been issues with HP computers and this error code occurring but nobody seems to know why.
If you believe that the hard drive is not faulty access the BIOS and look for the option HDD SMART Enable (or similar) and disable it.to enter the BIOS during the boot process you will see for a short amount of time to press a certain key to enter set up press and hold that key to enter set up(BIOS)
Do a reboot then get into the operating system and select the C: hard drive properties. On the tools page you will find a hard drive right click select properties tools place a tick in both boxes run it and it will tell you it cannot run as the drive is in use. It will then ask you if you wish to reschedule a test on reboot. Select that option and reboot the machine. This will report and fix and drive protocol errors that have occurred but it will NOT repair the drive if the mechanics are faulty. Replacement is the only way to fix that.
hope this helps
A 05 304 error code diff sound comes from the
That is a master disposal jam. Check to see if a belt is off in the disposal area.pull out the drum and disposal box to see the belts check you may need a flashlight.
WE HAVE A DIGIMERGE 9 CHANNEL DIGITAL VIDEO RECORDER MODEL DGR109. ALL THE LIGHTS ARE ON AND NONE OF THE PUSH BUTTONS WILL REACT TO ANY FUNCTIONS ALSO THE MEMORY BOX SAY IT IS FULL.
if you can access the menu start by formatting the hard drive
here is a link to the manufacturers website they have manuals and most importantly updated firmware
http://digimerge.lorextechnology.com/cgi-bin/new_digimerge/index.cgi
2helpful
Umax Astra 6700 download driver error code 129
here is your code mines
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER
Lorex 4 Channel Business & Home Security Digital Video Recorder with 80GB Hard Drive Logo
Top Lorex Home Security Experts
ADMIN Canada
ADMIN Canada
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
