Tally LA650 Matrix Printer Logo
Posted on Feb 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHAT IS DEBIT NOTE
Tally
mukhtar21 shaikh
Level 3:
President:
  • Tally Master 2,022 Answers
  • Posted on Feb 10, 2010
mukhtar21 shaikh
Tally Master
Level 3:
President:
Answers
2022
Questions
Helped
668882
Points
5817
It is a sales document used in complaints processing to request a debit memo for a customer. If the prices calculated for the customer were too low, for example, calculated with the wrong scaled prices, you can create a debit memo request. The debit memo request can be blocked so that it can be checked. When it has been approved, you can remove the block. It is like a standard order. The system uses the debit memo request to create a debit memo.
A transaction that reduces Amounts Receivable from a customer is a credit memo. For eg. The customer could return damaged goods. A debit memo is a transaction that reduces Amounts Payable to a vendor because, you send damaged goods back to your vendor.
Have a nice day and do not forget to rate please...!
1helpful
I wish to update my Debit Card details as my present one expires shortly and i shall be changing my bank
Follow the instructions below to update your debit card details.
1. Sign in to your PayPal account (www.paypal.com)
2. Under "My Account" tab, click on profile
3. Click on "Credit/Debit card" under "Financial Information"
4. Click on "Add a card" button
5. Enter your new card details
6. Click on add or submit button
Note: you can also remove your old card details on that section.
Hope this helps
33helpful
4answers
I Want All Important Notes Of Tally erp9
www.tallysolutions.com/.../TallyPDFs/Tally.ERP%209%20Release%20Notes.pdf
Tally 6218 hammer voltage 2
Hammer Voltage 2 is the worst error you can get on the Tally T6200 series...
Explanation:
A high resistance coil fault has likely occurred in one or more of the
hammer coils.
Note: This fault message will have been preceded by printing slow-down
attempts associated with On-The-Fly thermal monitoring of hammer
bank temperature. Check blower underneath ribbon Deck.
Corrective Action:
Check the hammer bank for defective hammer coils qty 7 per hammerbank.
Confirm that hammer drive board is functioning properly.
8helpful
4answers
How to select all sales entry in tally 9 and how to delete it
Select all sales entry one by one by pressing space bar, & after selecting all the entries. Siply press Alt+D. all the selected Entries Deleted at once.
Note:- This feature is available on in original Tally Users not for Crecked Tally.
Sachin Sharma
Axis Convergence Pvt Ltd
Noida
19helpful
3answers
How to find tally 9 short-cut keys
Tally 9 short-cut keys appear on the right-side of the tally screen. see the button names in the button bar.
few short-cuts:
Keys
Functions
Alt + 2
To Duplicate a voucher
Alt + A
To Add a voucher
To Alter the column in columnar report
Alt + C
To create a master at a voucher screen (if it has not been already assigned a different function, as in reports like Balance Sheet, where it adds a new column to the report)
To access Auto Value Calculator in the amount field during voucher entry
Alt + D
To delete a voucher
To delete a master
To delete a column in any columnar report
Alt + E
To export the report in ASCII, HTML OR XML format
Alt + I
To insert a voucher
To toggle between Item and Accounting invoice
Alt + N
To view the report in automatic columns
Alt + P
To print the report
Alt + R
To remove a line in a report
Alt + S
To bring back a line you removed using ALT + R
Alt + U
To retrieve the last line which is deleted using Alt + R
Alt + W
To view the Tally Web browser.
Alt + X
To cancel a voucher in Day Book/List of Vouchers
Alt + Y
To Register Tally
Ctrl + A
To accept a form – wherever you use this key combination, that screen or report gets accepted as it is.
Ctrl + Alt + B
To check the Company Statutory details
Ctrl + G
To select the Group
Ctrl + Alt + I
To import statutory masters
Ctrl + Q
To abandon a form – wherever you use this key combination, it quits that screen without making any changes to it.
Ctrl + R
To repeat narration in the same voucher type
Ctrl + Alt + R
Rewrite data for a Company
24helpful
5answers
Have a problem in tally 7.2
Dear Archana,
If you are using tally legal. Please check whether the date & time are correct. If correct then check the data folder file permission (readonly, hidden, system attributes) are removed. If not while starting tally press Ctrl + Alt + R for and select company which one is getting error. It will rewrites the data of that particular company. Then close tally and open again check it. If this doesn't work u should contact tally support with u r licence key and product id.
Thanks & Regards
Nanda Kishore
Top Tally Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
