Question about Tissot Diver Seastar 1000 T19.1.593.51 T55.8.283.11
It works intermittently even when worn. what u tink is d problem?
Posted by wongypoo on
David Tolond
    President:
  • 2,501 Answers
First try having a new battery fitted.
If this does not solve the problem, then ask a local watch repairer to sort it out for you.
Posted on Feb 10, 2010
I have 2 movt wrist watches work good when left off wrist but when worn will stop working after worn 6to8hours WHY
Check the two connections where the battery makes contact, most likely one of the screws is loose or missing, or may have some corrosion from a battery leak..
Feb 19, 2015 | Watches
I've not worn my watch in 7 years. I did not think it had a battery. It charged from movement. I tried to wear 2 days and still it does not work.
It probably needs a good cleaning and lubrication. This can be done at any watch repair shop, even the ones they have in Sears department stores, if you have no specialty shops in your are.
Dec 07, 2011 | Tag Heuer Watches
Stops after i take it off, I have to shake it to get it going again, problem is intermittent, I have no clue...
Your watch is self winding and will run down (if fully wound) for about 2 days.
This type of watch thrives on use and if not used will stop. To avoid having to re-wind by shaking, it should be worn every day.
(Some makers say that to full wind up their self winding watches, they need to be shaken (gently) aboiut 200 times).
Apr 15, 2011 | Rolex Daytona 116520 Wrist Watch
The second hand is not moving even when i wind it
This watch is an automatic type and may you not be able to wind it up use the crown wheel (winder). The details on their web site do not describe the operation of the watch, so I can't be absolutely sure about this.
You can wind an automatic watch by swinging it genetly from side to side for few minutes.
When fully wound, the watch will remain working for 42 hours (when not being worn).
These watches thrive on being used and if used daily, they should remain operating.
Dec 24, 2010 | Christian Dior Dior Chiffre Rouge...
I have a Luminox 3050/3950 series which stopped working after almost 2 years from buying it.I thought it was the battery so I tried to change it my shelf, but even after the replacement of the battery the...
Generally after two years power cell life will over.
> are your replaced same battery? check the voltage of power cell _1.5V
> Observe that seconds needle giving any jerks? if its trying to move its overhaul faulty, give it to good service center for overhaul.
> If its not at all moving at all it might be coil or PCB faulty..
Sep 09, 2010 | Luminox Navy SEAL Dive 3901 Wrist Watch
Handleiding
mcdevito75 here, I think you mean handleing, or takeing care of your Casio watch. First look on the back cover to see if it says shock proof or water proof, if it does you have a liitle lee way in handleing your watch, what I men is, you can wear your Casio even if you do heavy work and even in a moderate rain. However most Casio watches should not be worn if your out in a driveing rain or if you do extra heavy work, such as use a sledge hammer, or heavy tools, keep your casio dry, and once every other daye wipe it clean with a soft dry cloth, also do not rest your Casio on it"s crystal (Glass) when you take it off.
Jun 16, 2010 | Casio G3011 Duplex LCD Watch
My Pulsar YT57 stops after 2/3 days if not worn even after previous continual use for several days, the instruction book refers to up to 6 months. L.Charlton.
You have to find your nearest watch repair shop and ask to replace CAPACITOR. This is a short name for Kinetic E.S.U. used by watch professionals. After replacing this part your watch will run as new and will keep power reserve as described in this manual:
http://www.pulsarwatches.com.au/manuals_pdf/73_1.pdf
P.S. I would recommend to charge the watch as described in manual first, and only if it does not work, go to the repair shop.
Rate me, please.
Jul 31, 2009 | Pulsar Watches
I just recently purchased a brand new Casio G-Shock GW-002KA 2913
if there is a black screen and shows chg thats mean your battery level is to low ////// so you must charge as soon a possible,,,,,,
Jan 21, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Ho do I charge my Citizen Eco Drive Ladies EW8622-53A watch for the first time?
Hi leave under a strong light for a few hours, normal wearing should then be sufficient.
If only worn intermittently leave out in the light, do not put in draw or anywhere daylight can not get to the face of the watch.
Nov 29, 2008 | Watches
I have a Thomas Kinkade "The Light of Freedom" Pocket Watch, an it stopped working, is there a way to wind it up.
good after noon ! i tink your watch is need of general cleaning ! thank you !
Aug 25, 2008 | Watches
Tissot Diver Seastar 1000 T19.1.593.51 T55.8.283.11 Logo
Top Tissot Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anonymous
Level 1 Expert
Are you a Tissot Watch Expert? Answer questions, earn points and help others
