Question about Cell Phones
Unable to pair bluetooth Plantronic 975 with BlackBerry 9700
Unable to pair bluetooth Plantronic 975 with BlackBerry 9700, please advise
Posted by clickforsam on
Anonymous
    New Friend:
  • 35 Answers
On your Blackberry, navigate to Options,Bluetooth,Hit the cursor, Select Options, Set Discoverable to Yes, and save.
Make sure your Plantronic is in pairing mode.
On the Blackberry, hit the return key, add device, Search, Pllantronic will be listed on the blackberry as found. Select it, and add the password which by default is 0000.
Posted on Feb 10, 2010
3helpful
I have a plantonics headset that does not pair with my I phone 4s, I have pressed the button on it until the light comes up but no results, I have a plantonics 975
Turn on Bluetooth option within your phone - Consult phone instruction booklet
Put phone into pairing mode - Consult phone instruction booklet
Put the 975 headset into pairing mode - With the 975 headset on, press and hold Call Control Button until the headset begins to flash red and white.
Select "Add new device" on your phone.
Select the Plantronics 975 headset when prompted. Enter "0000" as passcode.
Your 975 headset will now have a continuous white light blinking.
Choose "Yes" if your phones asks if you want to bond to the 975 bluetooth headset.
Your phone is now paired with the Plantronics 975 headset and ready for use.
Dec 22, 2012 • Cell Phones
Cannot get plantronic device to pair with my blackberry
Try turning off your phone and headset. Turn your phone back on and put the headset into pairing mode (the headset needs to be turned off when starting the pairing mode) pull up your menu on your Bluetooth phone and select the headset then try reconnecting the two again.
Good luck from Headsets Direct!
How do you pair with blackberry 9700
Once you make your Blackberry discoverable, then put the Plantronics M100 headset into pairing mode by holding the call control button until the headset flashes red and blue. Below is the link below for the M100 user guide with the pairing instructions.
M110 User's Guide
2helpful
I am unable to receive pictures, music from other mobile phone to my BB Bold 9700 through Bluetooth. Both devices are pairing but BB is not receiving sending is not a problem.
you should select the option "receive via bluetooth". in the media menu, press the menu button (the bb symbol) then select receive via bluetooth, then send the file. you will then be able to receive files from other phones.
hope this helps. also please rate. thanks!
BLACKBERRY 9700 BLUETOOTH CONNECTIVITY
in the media menu, press the bb button then select receive via bluetooth
My blackberry bold 9700 bluetooth is not compatible with my laptop windows vista sp1. I am unable to transfer my pictures or music files to my blackberry via bluetooth. how do i solve this problem?
you have to select the option "receive via bluetooth" to be able to receive files to your phone. this can be done when you are in the media folder. press the menu button, then select "receive via bluetooth" when sending files from your pc/other phones.
1helpful
2answers
Blackberry bold 9700 Bluetooth problems
Many quirky behaviors for these devices are fixed every time a new software version is released.
You might check that you are using the most current system software for your BlackBerry Bold 9700 Smartphone.
The latest software as of March 20, 2010 is BlackBerry Handheld Software v5.0.0.64
Instructions for reinstalling BlackBerry Bold 9700 Firmware and System Software are here.
Recently just got my new 9700 bold but am having problems with the bluetooth function. I cant seem to receive any files from other bluetooth devices?? I read somewhere that on Blackberries you need to go...
Some blackberry don't receive through blue tooth.,it 's just there for decoration.
look around and see if any other black berry receives through blue tooth....
Cell Phones Logo
Top Cell Phones Experts
Ekse
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
