The sub is a dual voice coil, and depending on how you wire them, gives you different bass response as it drops the ohms in your amp. it can be wired for 2 ohms one way 4 ohms another way or 1 ohm depending on what ohm the coils are. to learn more about this got to rockford fosgate.com, click support, then click woofer wiring wizard, this will answer all your questions about dvc subs.
SOURCE: TROUBLE WIREING SPEAKERS
Lots of info here; http://www.the12volt.com/Default.asp? You have to register, but its free. Best of Luck.
SOURCE: how to wire a kicker 15 cvr
175W x 2 @ 2 ohms
350W x 1 @ 4 ohm
Your amplifier is not stable @ 2 ohm bridged. So you will have to wire them independantly on each channel.
+/- on sub to +/- on L channel
+/- on sub to +/- on R channel
Wiring the subwoofers in paallel will result in a 2 ohm load, which your amplifier is not rated to do. Doing so will cause heat buildup, and damage to the amplifier.
SOURCE: my subs sound distorted and dont pound right
Are you sure the polarity is correct on the sub's connectors? This is very important as reversing them will cause the sub to pound inward instead of out. Make sure the wires are thick enough and that the amp's + connector goes to the red(or +) connector on the sub and that the amp is grounded properly to a clean piece of metal on the car's body. This ground wire should also be as short as possible. Also make sure the fine-tuning for the bass level on the amp is adjusted correctly and that the sub's enclosure is the correct specification ie. Ported or sealed, right size, etc.
SOURCE: help wiring kicker cvr12's
Hello pr7met7me,
Assuming that the "old sony box" has 2 chambers with at least 1 cu/ft of internal volume each, there should be no problem running the Kickers. The CVR's are dual voice coils and come in either 2 ohm or 4 ohm versions. The coils are wired together either in parallel or in series and then wired to the box terminals.
You did not specify what make and model of amp that you intend to use. The amp will dictate how the sub voice coils are wired. You do not want to go below the minimum load that your amp is capable of supporting. If your subs are the 2 ohm version, you wire the dvc's in parallel and then parallel both subs to the amp, your final load to the amp will be 0.5 ohm and there are not many amps stable at that low of an impedance.
The terminals with the white dots are for the first voice coil. The terminals with solid-red and solid-black markings are for the 2nd voice coil. In a parallel setup, you would wire the white-dot positive and the solid-red terminals to the box internal positive and the white dot negative and solid-black to the box internal negative. In a series setup, you would run a jumper from the white dot negative to the solid-red and then connect the remaining terminals to the box terminals.
Hope this helps.
