Make Model
Honda XL 125R Paris Dakar
Year
1983
Engine
Air cooled, four stroke, single cylinder, OHC, 2 valves per cylinder
Capacity
124
Bore x Stroke
56.5 x 49.5 mm
Compression Ratio
9.4:1
Induction
PD52
Ignition / Starting
CDI / kick
Max Power
12 hp 8.7 kW @ 9000 rpm
Max Torque
10 Nm @ 8000 rpm
Transmission / Drive
6 Speed / chain
Front Suspension
Telescopic forks
Rear Suspension
Swinging arm
Front Brakes
Drum
Rear Brakes
Drum
Front Tyre
2.75-21
Rear Tyre
4.10-18
Seat Height
840 mm
Dry-Weight
109 kg
Fuel Capacity
17 Litres
SOURCE: 1979 Honda XL 125, only 600 miles on it. The
you can get them re-cromed but its costly why not just paint them black with heat proof engine paing
they go rusty becouse of the heat in them and its a good con by honda to use realy cheap crome parts
just get some hight temp black paint the will still look good after this and its far better that red rusty pipes!
Testimonial: "You're right. A little sanding and flat high temp black. Thanks."
