According to HP's specifications, your computer came with a 250GB SATA (serial ATA) hard drive. All drives have standard mounting dimensions, so any SATA drive would be compatible. HP has manuals here that give detailed steps on how to change the drive if you need help. It's a very simple process. Then yes, just put in your recovery disc and reload the original software. You'll then need to reinstall updates, any applications you put on, and so on.
Hope this gets you running again soon. Thanks for using Fixya!
HP recovery discs can be used to return a computer's software configuration to its original condition. HP provides a recovery solution on the hard drive, but it is still a good idea to keep recovery discs stored in a safe place in the event of a hard drive failure. Use the sections in this document to obtain a recovery solution that works best for you.NOTE:HP computers designed for commercial use, such as Workstations or Pro series, use "Operating System" or "HP Restore Plus" DVDs. To order these types of discs, go to the HP Replacement Part Store . Recovering your computer without recovery discsYou may not need recovery discs to recover the software on your computer. HP provides a recovery solution on a separate area of the hard drive. If the hard drive is still functional, you can still perform an HP system recovery from the hard drive as long as the recovery information has not been destroyed or corrupted.To do a software recovery from the hard drive, turn on the computer and repeatedly press the F11 key until "Windows is loading files..." displays on the screen. If your computer originally came with Windows XP or earlier, press F10 to enter recovery instead of F11.If you are simply trying to restore the computer to factory install, you may not need the recovery discs.
