While holding the eject button, turn the main switch on, when the power light is green, release it and you should hear a beep.
The fan will operate at the highest speed possible and will eject any disc that is inside.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and the red light will blink. When this happens, turn the main switch off and on then turn it on normally.
Turn the PS3 off with the main switch on the back.
Turn the PS3 back on into standby (red light on)
While holding the eject button press the power button on the front of the PS3. This should initialize a forced disc eject.
its called the red light of death in order to eject the disk you have to 1.power off the console
2.Press the eject button and the power button while turning the switich back on on the back of the ps3
3.wait a few seconds and the disk should come right out
Send it in for service at a Sony playstation service center. It is possible you have a hard drive problem, but you will basically need to buy a hard drive and install it to find out.
does the light blink red?
if so you have the TERRIBLE BLINKING LIGHT OFF DEATH
you have a few options:
1.call sony, send in your ps3, recieve a refurbished ps3 for $150
2.find a local to fix it for much cheaper
3.buy a new console
It might be a problem with your coolers. To test it, turn the key behind the console off, then hold the eject button and turn the key you switched off on (while holding the eject button!!). it will make your coolers work at maximum speed and might clean the system .
if it doesn't work, try taking the ps3 to it's warranty, because it might be, also, problems with your CPU .
