You can deactivate silent mode you need to follow this simple steps first select menu then scroll to settings select this one then scroll on to the profile icon and select it there you will get number of list have silent,general,meeting,light only,discreet,beep sound,loud.Select general for canceling silent mode..All this mode contain different advantages one can have only vibrate selected and other can have low ring volume select the icon what time of sound you like.
You can simply change by changing the profile on your phone, if the phone is put on silent profile then it will be in a quite mode, go to the menu of the phone, then select settings, select phone settings, there you will see phone profile, then select Normal profile, this will deactivate the quite mode of the phone. Depending of the phone you are using, like my samsung d780, I simply hold down the # key to deactivate the silent mode, check your phone keypad as well to see if there is a key like that, but if there is no key like that simply follow the steps I put above. Thanks
Press and hold the # button until it tells you its on normal mode. If this still doesnt work go into settings, profile settings, then i think it will be general and change the ring/message tone as it must be on off..if that makes sense. hope i helped.
To place the handset in silent / vibrate mode follow the steps below:
To place the handset in Silent Mode, hold down the pound key (#) for about 2 seconds. To exit Silent Mode, perform the same action while in Silent Mode. You will see a confirmation message for Silent Mode, each time you enter or exit Silent Mode.
The phone will vibrate rather than ring when you receive a phone call, message or alert while in silent / vibrate mode.
