Sounds like you have it on zoom setting. Go to the picture menu and scroll through the options. Start with 16:9 and try others if this doesn't work. If you've already tried this, you may have to go into screen setting and manually draw the picture in horizontally and vertically - but make sure you've got it on 16:9 and paused on a typical picture before you mess around with these settings.
Hi, Don't put screen in direct sun light or bright light. Bright lights will destroy LCD screen. The LCD screen has some adjustments on back. You might be able to readjust picture brightness.
Good luck.
Yes there is but you have to get into the service menu and its a risky business to go there without knowledge of these adjustment.In any case these adjust would be called vsize,vpos.Any local repairman should be able to fix that in 5mins. good luck
On the opening frame when you turn it on Scroll through the icons to "setup" . Press enter.. A screen will come up sayinf "set up menu-photo setting"..Scroll down the left column to the center multi color icon and press enter. Press the right arrow on the handheld. In the grey box that comes up you will see various controls.. The third on the list is "brightness" . Press enter and then right arrow .. Scroll to setting you desire. (Normal, bright or soft are offered).. Good luck..
I also posted a question that you may know the answer to. How do I load photos on to the unit from my computer. I see there is a USB port on the Sunpak and I have a USB port on my computer .. but no cord with 2 USB port ends?
DH-L
No. Aspect Ratio is same for UAE and India, and also the broadcast System.
Most Cable TV operators in India broadcast the signal 'slightly oversized, and so the viewer gets the Scrolling at the bottom and top of the screen cut-off.
This is a defect in the vertical scan amplifier. It is not an adjustment. Most of the time there are a number of capacitors in the vertical deflection amplifier that can cause this type of fault. Sometimes the output drive IC can cause this fault, but more rarely.
An experienced service tech can locate the defective parts and replace them. The average time involved is about 1 to 1.5 hours.
Usually when the vertical starts shrinking slowly, it is due to capicators getting out of tolerance in the vertical output section of the chassis. If it can be adjusted out through a service menu, you'll probably need a tech with the right equipment to perform it.
