Question about Toshiba DVR670 Player
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find in the TV guide. I don't get a TV guide. But I can see the time the program starts and stops on my cable menu. I want to set the timer using the time, not those codes. Can I do that on this VCR recorder?
Posted by kgscott22 on
Demonic-2011
  • Toshiba Master
  • 512 Answers
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Posted on Mar 09, 2011
cerwin
    New Friend:
The DVR670 only works for about 6 months then errors out. These units are JUNK. Dont waste your money on any Toshiba products. Their customer support sucks.
Posted on Mar 20, 2014
It will not timer-record some channels such as Channel 5-2 and 9-2. I can manually record on those channels, but when I try to record using timer programming, it won't record those channels.
If Toshiba offered you a refund due to the alleged bug, I doubt that there is a work around to the problem. If it had been a regular tuner I would have suggested that you scan all the channels to commit them to memory.
The problem basically is that those channels re not in the recorder's tuner memory. You can enter them manually but when you try to use the programming the unit will not do it since channels are not in memory. Check your manual to see if there is a provision for getting channels into the memory of the unit. Don't hold your breath.
Sep 10, 2015 | Toshiba DVR670/DVR670KU DVD/VHS Recorder...
How do you use the VHS function on the Toshiba DVR670 player?
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
Oct 20, 2011 | Toshiba DVR670 Player
We recently connected to Direct TV...I want to transfer some old western TV Shows I recorded on my Direct TV DVR Recorder to VCR Tape. I was told by the people at Direct TV that I would need to contact you...
You can try this: Connect your DirecTv to VCR with Red/White/Yellow cables. Then the VCR to your TV with the same type of cables. Make sure the VCR is set to the video input, not the tuner. Turn your TV to the correct video input. Get the program ready on the DVR as if you were going to watch it. Press record on the VCR and then play on the DVR. At the end of the program, press stop on both. You may have a problem with the video recording properly. Some stations broadcast with copyright protection.
Apr 12, 2011 | Emerson Televison & Video
I have a Toshiba VCR w522 and would like to record a program previously recorded from a DVR. Is it possible?
If the vcr has two scarts connect the DVR player to one and select that imput. Watch the program using the the other scart connected to the TV. Press record on the vcr and then start the DVR player going. If it doesn't have two scarts use the front panel jacks to connect the DVR player.
The only time you won't be able to record a program is if somekind of anti-copy system is employed.
Aug 31, 2010 | Toshiba W522 VHS VCR
My Toshiba DVR670 dvd recorder/vcr combo. When I turn on the combo and have a tape in it it will display in the bottom lefthand corner the letters SP and an arrow pointing up with a line under it above the...
need to repair or replace the unit more likely the VCR belts are not tight enoughsince the advent of DVD recorders the quality of VCR components has gone way down I have 3 combo units the only one that still records is in the unit which only has a DVD player in it. and even that won't allow tracking adjustment
Dec 07, 2009 | Electronics - Others
How to record on vcr/dvd combo I set the timer program to record on the vcr but nothing happen, I can record by hitting the record button, but unable to get the timer to work. I received the vcr/dvd combo...
First make sure the internal clock is setup correctly observing am/pm. Then try recording something so you can watch the operation to see if it works. Make sure you have a tape you can record on and also make sure the write protect tab has not been removed from the front lower corner of the tape. Good Luck! I hope you now have success!
Nov 11, 2009 | Toshiba Televison & Video
How to record mutliple programs with a converter box
You will not be able to record like you used to: http://www.ezdigitaltv.com/VCRs_and_Converter_Boxes.html There are some boxes that have a timer, but not many.
Jun 14, 2009 | Insignia Digital-to-Analog Converter for...
Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
BWLY
Jan 23, 2009 | Toshiba MV13M2 13 in. TV/VCR Combo
Magnavox TV/VCR COMBO
Im thinking that maybe you a have a timer recording set. The whole unit wont function at all if you turn it on via power button (remote or unit). There should be a button at the top of the remote called 'timer set' pressing this will disable that mode and allow complete use of everything. but make sure u press timer set again when powering down, otherwise simply turning off the machine will leave the timer recording disabled.
Oct 17, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Samsung DVD-V4600A Combo DVD / VCR will no longer timer record to Videotape
Storms tend to fry most delicate electronics. Quality surge protection is required.
Ben
Jul 25, 2008 | Samsung DVD-V4600 DVD Player/VCR
Toshiba DVR670 Player Logo
148 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
