Question about NorStar T7316E Phone
Need Help! I have a nortel T7316E, for some
Need Help! I have a nortel T7316E, for some reason when I pick a line to dial out it says Denied in Admin. Have used that phone many times before and never had a problem. Somehow a setting or something was changed?????
Posted by irmag on
tfelton3
    New Friend:
  • 183 Answers
Go to tek-tips.com they have a Nortel Norstar and BCM section in there that will get you the help.
Posted on Feb 09, 2010
Denied access on Nortel T7316E Log# 1020000 will not work..How do I fix this?
Follow this instructions to reset the Administrator password.
Press Feature 985 and dial 9 even though it is not listed as an option.
The display will show Pswd: dial 73738767793
The display will show Reset pswd? Press YES.
You should now be able to enter the default password.
2 digit extensions use 120000
3 digit extensions use 1020000
4 digit extensions use 10020000
Jul 31, 2012 | Nortel Networks T7316E Telephone Platinum...
I have 4 lines that were made into speed dial numbers then deleted. On this phone (although not other phones on the same network) they now appear as "blank". If calls are put on hold from another phone to...
You call your Nortel service tech, unless you know the installer password and are familiar with programming. You have to go back into set programming and reassign the lines.
May 20, 2010 | Nortel T7316E 2-Line Corded Phone
We have a Nortel T7316E & want to transfer live calls to cell
transfer (under screen when on a call) is for internal transfer. you need the external transfer feature from your phone company, then a "link" key programmed on your phone. link is also feature 71. when on a call you hit link or feature 71, then dial the cell or have speed dial buttons for them,.
Apr 20, 2010 | Nortel T7316E 2-Line Corded Phone
I should be able to use Feature 75 to pick up an incoming call; however, when I try the phone tells me that it is denied in admin. How do I fix this?
more than likely your not in the same pick up group as the phone that is ringing. Instead of setting up pick up groups you could use feature 76 (directed pick up) if you know which set is ringing.
Apr 08, 2010 | Nortel T7316E 2-Line Corded Phone
I have a used Nortel Networks T7316E and for some reason when I plug it in to the phone line at home I get no dial tone and the light at the top and the three buttons on the bottom (headset)(Mute) etc......
The Nortel 7316 set is propriatary which requires the nortel system in qrder to work., The pulsing lights are the set reacting to the standard line voltage.In order for it to work in your house you'll have to install the nortel phone cabinetand then attach the set(s) to it.
Jan 19, 2010 | Lands Phones
Nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
Is the nortel 7316 analog?
No, the T7316 set is digital, this is the reason why you cannot just take it home and have it work. Two different styles of signalling. The T7316 set only works with Nortel Systems.
Jun 15, 2009 | NorStar T7316E Corded Phone
Unable to see if an internal extension is engaged
It doesn't exactly work that way, but you can program the extensions back under the buttons. Pick a button that you want to save an extension under and press FEAT *2 the button and dial the 2 or 3 digit extension number. Now the button monitors the status of the extension. It will light whether it's in DND, or busy on an outside or internal call.
Carl
May 21, 2009 | Nortel T7316E 2-Line Corded Phone
Want to pick up phone and get an outside line
Yes, put your lines in a line pool, then have your phone automaticly go to Line Pool: <Whatever Pool # you picked, 1 thru 3>
Dec 17, 2008 | Nortel T7316E 2-Line Corded Phone
Lands Phones Logo
1,243 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
martin hogg
Ekse
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
