Question about AT&T ATT-974 Corded Phone
I have a ATT 974 phone and callerid is not working on the phone? any suggestions.
Posted by ryankelley on
Anonymous
Disconnect battery and power cord. Then plug back in. See if this works.
Posted on Aug 23, 2010
Set up voicemail
I would also suggest downloading the manual. I have my answering service thru att and I call a phone # assigned to me to check messages at any time.
http://cdn-media-att.vtp-media.com/ecp/documents/product_Product/208/UserManual/537/974_Manual.pdf
Mar 28, 2014 | AT&T ATT-974 Corded Phone
My caller id is not working on my at&t 974 phone
Same thing happened to me. Here's what I did: 1) Unplug phone. 2) Remove backup battery. 3) Wait at least 5 minutes. 4) Plug phone back in and insert battery.
Step 3 is important. I only waited about a minute the first time and the problem remained.
Jan 07, 2014 | AT&T ATT-974 Corded Phone
ATT-974 Low Battery incdicator
maybe the new battery is in stock for a long time. then it is in low power.(http://www.my-batteries.com/digital-camera-batteries/sony-np-fr1.htm)
Aug 03, 2012 | AT&T ATT-974 Corded Phone
Line 4 on my 974 AT&T Phone is flashing when not in use?
1) reset the base . TURN OFF wait by 3 minutes. this to due the remain "effect memory" in the battery and try again.
2) must be dissapear, this happen when the are shut down of energy or similar.
3) if the problem persist Read YOUR owner manual, and go to the section troubleshooting and fix it. However you can assist ONLINE via chat or phone.
God bless you
Jul 25, 2012 | AT&T ATT-974 Corded Phone
974 att phone has all lines busy, how do i fix that?
Do you mean they are all red? Do you have all four lines being used?
May 28, 2010 | AT&T ATT-974 Corded Phone
AT&T 974 Caller ID has quit.
Unplug everything then replug should reset the Caller ID
Dec 11, 2009 | AT&T ATT-974 Corded Phone
I have a 974, 945, and 955 phones in a 2-line office. I am getting a squeal on the intercom when I call just one phone. It works fine between other phones. It worked for 2 years and then the squeal showed...
Check the battery on all the phones then make sure they are all programmed with different extension numbers. If the battery has been dead and you have had a power outage then it may have reset the phone to factory default extension 11.
Dec 03, 2009 | AT&T ATT-974 Corded Phone
ATT/Lucent 854 ringing after power outage
Press PROGRAM
Press *
Press #
Enter 2 digits (11 through 22)
Press INTERCOM
This should work.
Mar 22, 2009 | AT&T ATT-974 Corded Phone
AT&T 974 model small business system
How do I change the number of rings on the phone before it goes into voice mail? If I am not beside the phone, after 2 rings it will go into voice mail and I am missing calls. The model is AT&T 974.
Jan 15, 2009 | AT&T ATT-974 Corded Phone
AT&T 974 corded phone
if your dsl is on the same line it will mess up micros for intercome system. Move dsl to another line
Jun 17, 2008 | AT&T ATT-974 Corded Phone
AT&T ATT-974 Corded Phone Logo
271 people viewed this question
Top AT&T Lands Phones Experts
Marvin
Marvin
Ed
Ed
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
