Uniden DCT646-2 Cordless Phone Logo
Posted on Feb 09, 2010
Can't get if off MUTE. I can hear people who call, but they can't hear me.
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Feb 09, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
618
Points
12
Check your owner's manual to see if it tells you how to cancel the MUTE function. Look in the troubleshooting section as well.
I have a 3000 i can hear a call but they cannot hear me
Sounds like (pun intended) you have it on mute. Push the mute button or the mute switch. Isn't it funny how people sometimes use "mute" when they mean "moot" and vice-versa?
2helpful
When calling,i can hear the person i called but they cant hear me
Hi..
Looks like problem is on your side. This is may due to a faulty microphone on your phone or Mic is set to be on mute.
1. Please check that nothing is clotted on Microphone. This is a small hole on bottom side of your phone.
2. Please check that other party can hear you when you're using a Hands-free / Bluetooth ear phones with mic on it. If they can hear you, when you use a hands-free, problem is with your phone's on-board microphone.
3. You can also check that, while on a call, your mic is not set on Mute. This can be done as on call, select Options , look for Mute / Unmute. If Unmute is present, select it unmute the mic.
4. You can use Mute button Provided on the top side of the phone. While on the call, press this button to Mute / Unmute the mic. If the mic is set to Mute mode, other party won't hear any sound from you.
Hope this will solve the issue.
1helpful
I can hear the caller but the caller can't hear me
Look to see if the Mute button (or Hold button) has been pressed. If so, press the Mute (or Hold) button again to turn it off. With Mute ON, you can hear what your caller is saying, but they can't hear you.
2helpful
I can hear but people can't hear me
Try to unmute the headset. This may be your problem. The mute function is enabled through the volume buttons. Simply tap both volume buttons at the same time until you hear a mute tone. The mute tone when unmuting the call will be a descending tone. When you tap both volume buttons, if you hear a descending tone you have just disabled the mute function and your problem is solved. If the mute tone is ascending tones you have just enable the mute function and this was not the issue. If this is the case consult your user manual or contact Motorola for trouble shooting.
1helpful
My I use my H 710 I can hear my customers but they can not hear me. How do I remove mute? Thanks
6helpful
I can hear the other person but they can't hear me
Your headset may be muted. Try to unmute the call. The mute function is enabled through the volume buttons. Simply tap both volume buttons at the same time until you hear a mute tone. The mute tone when unmuting the call will be a descending tone. When you tap both volume buttons, if you hear a descending tone you have just disabled the mute function and your problem is solved. If the mute tone is ascending tones you have just enable the mute function and this was not the issue. If this is the case consult your user manual or contact Motorola for trouble shooting.
I can hear them but no one can hear me
Are you sure that there is not a hidden mute button somewhere?
Look for the troubleshooting on www.nokia.netope the other will startuo hearing y
I h
Mute is turned on cannot hear phone ring. How to turn mute off Mute is turned on . Have no dial tone can't call any one and can't answer the Phone How do you turn mute off?
I can't talk or hear outta my phone. I can dial people but i cant hear them and they cant hear. My phone model Cordless 5.8GHz Edge Dual Handset Phone System with Caller ID:
People can't hear me - Mute button?
I have the same issue with Uniden cordless DCX640 - the phone was working fine but it seems to be on mute
1helpful
2answers
H700 headset can't hear me!
Push both volume buttons at once to turn Mute off. You should hear two beeps, ascending in pitch to indicate mute is off. If they go down in pitch mute is being turned on.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
