Canon FAX-L350 Plain Paper Laser Logo
Posted on Feb 09, 2010
HOW DO I CHANGE A SPEED DIAL NUMBER - Canon FAX-L350 Plain Paper Laser
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on May 29, 2010
Anonymous
Contributor
Level 1:
Answers
38
Questions
0
Helped
9604
Points
73
1 Open panel cover 2 Press DATA REGISTRATION 3 Press V to display 2. TEL REGISTRATION 4 Press SET twice 5 Press ^ or v to find the number you want to change 6 Press SET twice 7 Enter new fax number 8 Press SET twice 9 If you don't want to change the name then enter SET once more. Otherwise enter the changed name using the number pad as if it were a mobile phone (2 = A, B, C etc) 10 To continue press DATA REGISTRATION 11 Repeat steps above for other numbers 12 To end press STOP
Need to reset speed dial numbers but cannot get the cursor to appear.
Dear
Storing One Touch Dial Numbers 1Press Menu, 2, 3, 1. 2Press the One Touch key where you want to store the number. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit. Storing Speed Dial Numbers 1Press Menu, 2, 3, 2. 2Enter a three-digit (a two-digit for FAX-4100e) Speed Dial number, and then press Set. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit.
Thanks.
How do i change my voicemail number?
Press phone/menu/settings. Is the speed dial for your voicemail showing correct in there? If so, and you are still reaching the wrong number, contact sprint and explain to them what's happening. It's possible your default vmail number has gone a little screwy in the number change.
the place to check your speed dial is phone/menu/speed dial.
I need to set up a number on speed dial and delete one.. i have a brother intellifax 4750e
1 Press Menu, 2, 3, 2.
2 Enter a three-digit Speed Dial number, and then press Set.
3 Enter a number (up to 20 digits), and then press Set.
4 Enter a name (or leave it blank), and then press Set.
5 Press Stop/Exit.
Changing One Touch and Speed Dial Numbers
If you try to store a One Touch or Speed Dial number in a location where a
number is already stored, the LCD shows the current name stored at that
location, then prompts you to either
1 Press 1 to change the number, or press 2 to exit without changing it.
2 Enter a new number and then press Set.
If you want to erase the number, press Clear when the cursor is to the left of the
digits.
If you want to change a digit, use left arrow or right arrow to position the cursor under the digit
you want to change, then type over it.
3 Follow the directions beginning at Step 4 for Storing One Touch Numbers or
Storing Speed Dial Numbers.
4helpful
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Have a lucent partner 18D system How do I change
If your changing the speed dial numbers under the individual buttons thats done by pressing feature 00, the button you want to change the speed dial number on, and enter in the new number.
If your changing the system wide speed dial numbers, From extension 10 enter in feature 00, press feature then the 3 digit code for the speed dial bank (600-699), then enter in the new telephone number. Either press feature and the next 3 digit code for the next number or press feature 00 if finished.
How do you set and delete speed dials on minolta 2800 fax
Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How do I change the speed dial outgoing number??
For personal speed dial numbers press feature *4 , enter in speed dial bank number 71-94 (256-279, it changes with different versions), enter number, press ok
- speed dial numbers 01- 70 are system wide speed dial numbers and are changed in system programming2.gif.System programming is done on M7310,M7324 and T7316 set only.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The 4 top line/feature keys are now used for programming2.gif.
enter in the speed dial number you wish to program(40-70) .
Press the chg key
1helpful
2answers
How to set a speed dial and delate old speed dial no
Just figured this out (though a lot of people seem to have tried giving an answer without seeing if it works.
Setting speed dial numbers doesn't allow you to choose one for the voice mailbox. Go to Messages -> Voice Mailbox Number (option 12). There you can change the number.
May 21, 2009 • Nokia 1100
2answers
Nokia 1100 speed dial problem
hi,
1.Take your phone 2.Click menu 3.Go to contacts by scrolling down 4.Go to speed dial
There we can assign the number as speed dial.
old marine
old marine
ZJ Limited
ZJ Limited
