Hello. I have an Athlon processor and would like to know which is the best model to upgrade to, if any:
Physical Memory 2048 MB Total, 1642 MB Free
Memory Load 19%
Virtual Memory 3431 MB Total, 3141 MB Free
PageFile Name C:pagefile.sys
PageFile Size 1536 MB
In use 20 MB
Max used 27 MB
Registry Size 2 MB (current), 120 MB (maximum)
Profile GUID {97d5c7c0-06c8-11df-b2e8-806d6172696f}
The system clock interval 15 ms
Motherboard Top <#TOC>
Property Value
Manufacturer eveshamvale
Model MS-7025
Version
Serial Number
North Bridge NVIDIA nForce3 250 Revision A1
South Bridge NVIDIA nForce3 MCP Revision A1
CPU AMD Athlon(tm) 64 Processor 3000+
Cpu Socket Socket 939
System Slots 5 PCI, 1 AGP
Memory Summary
Maximum Capacity 16384 MBytes
Maximum Memory Module Size 4096 MBytes
Memory Slots 4
Error Correction None
BIOS Top <#TOC>
Property Value
BIOS Vendor Phoenix Technologies, LTD
BIOS Version 6.00 PG
Firmware Version 101.110
BIOS Date 01/29/2007
BIOS Size 512 KB
BIOS Starting Segment E000h
DMI Version 2.2
Characteristics - supports ISA
- supports PCI
- supports Plug-and-Play
- supports APM
- upgradeable (Flash) BIOS
- allows BIOS shadowing
- supports booting from CD-ROM
- supports selectable boot
- BIOS ROM is socketed
- supports Enhanced Disk Drive specification
- supports INT 13 5.25-inch/360K floppy services
- supports INT 13 5.25-inch/1.2M floppy services
- supports INT 13 3.5-inch/720K floppy services
- supports INT 13 3.5-inch/2.88M floppy services
- supports INT 05 print-screen
- supports INT 09 and 8042 keyboard services
- supports INT 14 serial services
- supports INT 17 printer services
- supports INT 10 CGA/Mono video services
- supports ACPI
- supports legacy USB
- supports AGP
- supports booting from LS-120
- supports booting from ATAPI ZIP drive
CPU Info Top <#TOC>
Property Value
Number of CPU(s) One Physical Processor / One Core / One Logical
Processor / 64 bits
CPU Full Name AMD Athlon(tm) 64 Processor 3000+
CPU Name AMD Athlon 64 3000+
CPU Code Name NewCastle
Platform Name Socket 939
Revision DH7-CG
Technology 0.13 µm
Instructions MMX (+), 3DNow! (+), SSE, SSE2, x86-64, NX
Original Clock 1800 MHz
Original System Clock 200 MHz
Original Multiplier 9.0
CPU Clock 1809 MHz
System Clock 201.0 MHz
HT Link 803.9 MHz
Core 0 Speed 1808.9 MHz
Core 0 Multiplier 9.0
L1 Data Cache 64 KBytes
L1 Instructions Cache 64 KBytes
L2 Cache 512 KBytes
Memory Top <#TOC>
Property Value
Memory Summary Top <#TOC>
Property Value
Memory Slots 4
DRAM Frequency 164.4 MHz
Memory Timings 3-3-3-7 (CL-RCD-RP-RAS)
Device Locator Slot 1 Top <#TOC>
Property Value
Manufacturer Micron Technology
Part Number 16VDDT12864AY335F2
Serial Number E000CC66
Capacity 1024 MBytes
Memory Type DDR (PC2700)
Speed 166 MHz
Supported Frequencies 133.3 MHz, 166.7 MHz
Memory Timings 2-3-3-6-0 at 133.3 MHz, at 2.5 volts (CL-RCD-RP-RAS-RC)
Memory Timings 2-3-3-7-0 at 166.7 MHz, at 2.5 volts (CL-RCD-RP-RAS-RC)
Data Width 64 bits
Manufacturing Date 2007, Week 9
EPP SPD Support No
XMP SPD Support No
Device Locator Slot 2 Top <#TOC>
Property Value
Manufacturer Samsung
Part Number M3 68L3223FTN-CCC
Serial Number F102B4FD
Capacity 256 MBytes
Memory Type DDR (PC3200)
Speed 200 MHz
Supported Frequencies 166.7 MHz, 200.0 MHz
Memory Timings 3-3-3-8-0 at 200.0 MHz, at 2.5 volts (CL-RCD-RP-RAS-RC)
Data Width 64 bits
Manufacturing Date 2005, Week 4
EPP SPD Support No
XMP SPD Support No
Device Locator Slot 3 Top <#TOC>
Property Value
Part Number 16VDDT12864AY335DB
Serial Number 0F0A12F7
Speed 166 MHz
Data Width 64 bits
Manufacturing Date 2006, Week 19
EPP SPD Support No
XMP SPD Support No
Device Locator Slot 4 Top <#TOC>
Property Value
Serial Number F104B4FF
Capacity 256 MBytes
Speed 200 MHz
Data Width 64 bits
EPP SPD Support No
XMP SPD Support No
Go to this link:
http://us.msi.com/?func=searchresult&keywords=ms-7025
Select the model motherboard you have and click on the CPU support link, it will show you a list of CPU's that are supported. You have a socket 939 board and AMD CPU's are now AM2, AM2+ and AM3 socket, which are 940 pin. It may be difficult to find a new CPU for your motherboard that is new since they have not been made in awhile.
