The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button
for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button
Is the wiring fault light indicator lit? This means that the outlet that the unit is
connected to is either not properly grounded, or has reversed wiring.
First, try connecting the unit to another outlet. If the unit does not display the wiring fault light
in the new outlet you will need to have an electrician correct the
problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
