Dear person in charge,
I'd like to know the maximum supported Hard disk capacity and memory of the following old Dell desktop models, can you help?
Dell Optiplex GX260
Dell Optiplex 760 Vista
Dell Dimension XPS D300
Dell Dimension XPS M166S
Thanks!
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
1) Dell Optiplex GX260:
A) Maximum TOTAL Amount of ram memory is 2GB's.
There are 2 ram slots.
EACH ram slot has a maximum amount of 1GB
Ram memory used, is either DDR Sdram that operates at 200MegaHertz, or 266MHz.
(PC1600 and PC2100 respectively)
B) Harddrive limit is 137GB. Harddrive style is IDE.
(Also known as PATA)
HOWEVER, (Not shouting), the computer can be fooled into 'thinking' there is a single 125GB harddrive, and you can use a 500GB harddrive.
To clarify, using a Western Digital harddrive for an example. The software that comes with WD harddrives, has a partitioning tool that you can access.
This partition manager divides a 500GB harddrive into 4 partitions, of 125GB's each.
Computer sees a 500GB harddrive as being just one 125GB harddrive, which is below the 137GB limit.
(Maximum allowable partitions on a harddrive is 4)
Dell Optiplex GX260 specifications:
http://www.austincc.edu/cloud/manuals/Dell/GX260/specs.htm
2a) Dell Optiplex 760 Ultra Small Form Factor:
A) Maximum TOTAL Amount of ram memory is 4GB's.
Maximum Amount for EACH ram slot is 2GB's.
With a Vista 64bit operating system, the full 4GB's will be recognized.
With a 32bit Vista operating system, only 3.2GB to 3.5GB will be recognized.
Uses DDR2 Sdram at either 800MHz, or 1066MHz.
(PC2-6400 and PC2-8500 respectively)
B) Uses SATA harddrives. Sky is the limit, and is only governed by the users budget.
(Up to 1TB)
You can also use external harddrives for any of the Dell models listed on this page, to increase your storage capacity.
(Plus Flashdrives. Also referred to as Flash Memory Drives, Thumbdrives, and USB memory stick, to name a few)
2b) Dell Optiplex 760 Desktop, Mini-Tower, and Small Form Factor:
A) Maximum TOTAL Amount of ram memory is 8GB's.
Maximum Amount for EACH ram slot is 2GB.
There are 4 ram slots.
B) Uses SATA harddrives. Sky is the limit.
3) Dell Dimension XPS D300:
A) Maximum TOTAL Amount of ram memory is 384MB.
Maximum Amount for EACH ram slot is 128MB.
There are 3 ram slots.
Uses SDR Sdram, (Commonly just referred to as Sdram), type ram memory.
Operates at 66MHz. (PC66)
It Should be able to use PC100, and MAY be able to use PC133 ram memory.
(This is governed by a number of factors for the last two stated. PC100 and PC133.
Depends on the CAS Latency, and Voltage. Also may depend on the Chip Configuration, and I believe only Non-ECC, unbuffered ram can be used.
CL should be 2.5
Ram timings - 2-2-2-5
Voltage - 3.3 Volts)
B) Harddrive limitation? Whatever came in it, is what I would stick with. (10GB? 20GB?)
Just my observation.
http://www.lyberty.com/tech/sysspecs/dell_xps_d300.html
4) Dell Dimension XPS M166S:
A) Maximum TOTAL Amount of ram memory is 64MB.
Maximum Amount for EACH ram slot is 32MB.
Uses SDR Sdram ram memory. Operates at 66MHz.
B) Harddrive limitations:
With all due respect, same as above for number 3.
http://support.dell.com/support/edocs/SYSTEMS/dter2/Specs.htm
Forgot to add:
I'm not the person in charge. That would be Lauren our Community Manager, the FixYa Support staff, and the CEO and founder Yaniv Bensadon.
I am just an Expert Moderator.
'I don't get to drive the train, but they do let me toot the whistle'
1) Harddisk technology:
Suggest you start here with IDE, (IDE is also referred to as EIDE, ATA, and PATA. The article below will explain why)
http://en.wikipedia.org/wiki/Integrated_...
(Also check out links that are listed in Blue on the page, as well as at the bottom of every page)
After you're done go back to the top of the page, and in the search box to the left type - SATA, (Then click on Search)
2) Ram technology:
Now type in SDRAM, then DDR Sdram, then DDR2 Sdram.
SDRAM is Synchronous Dynamic Random Access Memory.
SDR Sdram is Single Data Rate Sdram. Commonly just referred to as Sdram.
DDR Sdram is Double Data Rate Sdram
DDR2 is Double Data Rate 2 Sdram.
DDR3 is Double Data Rate 3 Sdram.
Also type in DIMM. (Dual Inline Memory Module. Module is correct computer speak for 'Stick'.
Stick is a slang term for Module)
Now type in CAS Latency. Then type in Memory Timings.
Take a look at this Motherboard Diagram,
http://en.wikipedia.org/wiki/File:Mother...
CPU stands for Central Processing Unit. Another name is Microprocessor, or for short - Processor.
This is the 'Brain' of the computer.
(Motherboard correct speak is - Mainboard. The Mainboard is the 'Building Block' of a computer, the Power Supply is the 'Heart')
Now use the search box,and look up Front Side Bus. (FSB) The FSB is the 'Information Highway from the CPU to the Northbridge.
The motherboard chipset is the Northbridge/Southbridge chipset.
'Chipset' is slang for IC. Integrated Circuit. (Use the search box)
Also look up Northbridge (computing), and Southbridge (computing)
(NOTE that the Northbridge chip only 'communicates' with the faster processes of a computer. Two examples are the Ram Memory, and high speed graphics, such as AGP, and PCI Express.
It does not handle the slower processes of a computer, such as anything inserted into a PCI expansion slot, the Harddrive, Ethernet, Audio, and so on.
Slower processes are handled by the Southbridge chip)
Check out PCI Local Bus, AGP, and PCI Express.
Also Intel chipsets, AMD chipsets, Comparison of Nvidia chipsets, and VIA chipsets.
Plus GPU. (Graphics Processing Unit)
Then, Intel GMA, and Comparison of AMD graphics processing units, and Comparison of Nvidia graphics processing units.
ATI Radeon, GeForce, and the links contained in the articles, (Listed in Blue), and at the end of each page.
Processor, and also List of Intel Microprocessors, List of AMD microprocessors, and List of VIA Microprocessor Cores.
MHz stands for Mega Hertz.
Mega = approximately 1 Million
Hertz stands for - Cycles per Second.
Giga = approximately 1 Billion
Byte stands for 8 Characters. (Generally accepted)
Characters can be numbers, letter, or symbols.
2, D, and $ for example.
One Bit = 1 Character.
Gives you a start here.
Now I suggest go to here,
http://computer.howstuffworks.com/
Click on Computer Hardware down on the left, then click on Hard Disks and Drives, and How Hard Disks Work.
Find out about the Platters inside. (There are generally 3 to 6 Platters inside a harddrive)
Platters resemble a CD disk, are composed of either metal or glass.
There is a magnetic medium applied to the Platters, and the Write portion of the Read/Write Head, arranges the magnetic media in a pattern of 0's and 1's, according to the information recorded.
0's are Off, and 1's are On.
The Read/Write Heads. (One on each side of a Platter. They are spaced about .0005 from the Platter.
That is 1/2 thousandths of an inch, or 1/6th the thickness of an average human hair. The average human hair is 3 thousandths thick)
This is so close, that the air underneath the Read/Write Head seems to make the Read/Write Head 'Float' when moving back,and forth across a Platter.
The Read/Write Head can move HUNDREDS of times a SECOND, going back, and forth across the Platter.
Also check out Memory. Click on Memory, then How Ram Works. Observe the animated Gif, that demonstrates how the ram memory cells work, and go on to read about Ram Timings.
Lots to learn, enjoy.
Hi Dageezer,
The info was very helpful. However, may I also request details of the Hard disk and RAM technology for eg.(IDE/SATA, DDR/SD, 555/667MHz etc)?
Thank you very much
