Question about Panasonic Televison & Video
Remote code for Panasonic TV/VCR combo
Remote code to use with Comcast Adapter Box and
Panasonic Model PV-C2021
  • Anonymous Feb 09, 2010
    Where di I find the remote code?
Anonymous
    New Friend:
Use the RCA universal control programing the code 109 in vcr funtion and will work..... i try and work....
Posted on Nov 23, 2010
How do I hook up my magma box DVD player to my panasonic pv- C2021 tv I don't have remote so how do I get to menu
TV Remotes Panasonic
I think the best answer is - get a new remote. The link is for Panasonic remotes, however, I did not locate your Model number, so double check the model number of your TV.
May 31, 2014 | Televison & Video
Remote codes for Panasonic MODEL# PV-DF2704
5 digit code for the comcast red button silver remote is 21462 this pertains to Panasonic MODEL# PV-DF2704
Nov 20, 2011 | Panasonic PV-DF2703 Triple Play 27 in....
I have a Panasonic pv-c1320 without the remote. trying to get the code through comcast digital transport adapter need a 5 digit code
Here are some Panasonic codes that Comcast lists on their website: 21062, 20035, 20162, 20225,
20614, 20616, 21035
(but the code depends on which remote you have, check Comcast's website for more info)
http://www.comcast.com/corporate/customers/customer_support/remotes.html
You can also try to manually search for the code:
Turn the TV on
Press TV or AUX
Press and hold "Setup" until TV/AUX blinks twice
Enter 9911 and press "Power" using the Comcast remote
Press "Channel Up" until device powers off
Press "Setup" to lock in that code
Please let me know if you found this helpful.
Have a great day!
Mar 16, 2011 | Panasonic PV-C1320 13 in. TV/VCR Combo
Remote Code for Comcast DVR
See http://www.comcast.com/corporate/customers/customer_support/remotes.html
You will most likely have to use a VCR code and program it to the AUX button.
Feb 26, 2010 | Panasonic PV-C2541 25 in. TV/VCR Combo
Need code to replace lssq0278 with comcast remote for dt adapter
Need code to replace lssq0278 with comcast remote, can`t make it work with codes on directory sheet
Oct 23, 2009 | Panasonic PV-C2022 20 in. TV/VCR Combo
I need the remote code to program my PanasonicTV w/
Panasonic 1162, 0035 (for TV use 0051)
Hope this helps you out. Its quite hard to get the codes for combi tv's
Please leave a thumbs up if this helps you out.
cheers Little Dish Fitter
Oct 06, 2009 | Panasonic Televison & Video
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Televison & Video Logo
1,113 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
