Question about HP Pavilion zd8000 Notebook
When I unplug power supply I get blue screen and it reboots. This is with a new fully charged battery in.
Posted by brewtocl on
Lee Hodgson
  • HP Master
  • 4,810 Answers
Thats a surge thats happening. The comutper will restart for data prevention purposes.
What i suggest you do is vist the HP Support website and select Drivers and Downloads. Input your model number and download the latest BIOS update. install the BIOS update and this should resolve the blue screen issue.
Regards.
Posted on Feb 09, 2010
Hi when i charge my motorola 1200a, I see on and off of screen, my battery is new.what I can to do?
Jaffarraja-
Not sure I understand. Are you saying your MotoMing a1200 is rebooting with the new battery or what?
Have you tried charging it overnight with the phone off? If the battery is dead and you charge it with powered on it might power up then power off. Best to charge powered down if battery is fully depleted.
Mark
Motorola Support
Feb 09, 2015 | Motorola Mobility MING A1200
My HTC mobile phone drains its battery too fast. I have to charge it every hour. This phone is brand new - only five days old.
turn the phone on and let it charge completelty. Then go and shut the phone off. Reboot the phone in CMV which is dos for phones. (you can do this bypushing a combination of buttons usually power, volume down and home check to see what yours is) go through the menus and look for Wipe Battery stats. IF YOU DO NOT SEE IT go back to the main menu and reboot phone. Wait for phone to fully charge again and shut it off. Now while it is off keep plugging the phone in till it says it is fully charged. Then unplug the phone wait ten-15 seconds and plug back in until it reads 100% when you plug your charger in
Apr 19, 2012 | HTC Cell Phones
My Blackberry curve 8320 won't turn on it just has a battery icon with a red line through it on screen. A new battery was tried and the problem still exists.
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails, retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in to cell store.
Jun 08, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Screen shows battery with a red line through it
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Feb 16, 2009 | RIM BlackBerry 7130c Cell Phone
Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Dec 06, 2008 | HP Compaq Presario R4000 Notebook
Toshiba satellite A210 11-P crashes when i disconnect the power lead
From Toshiba, try step-charging the battery or Battery conditioning procedures:
Batteries don't last forever. All types of batteries gradually lose their ability to hold an electrical charge as they age. Eventually, the computer's battery charge indicator may show that the battery contains less than a full charge, even though the battery has just been fully charged. The computer will then not run for as long a time from the battery as when the battery was brand new.
You may prefer to simply replace the battery if this happens, but you may also wish to try 'step-charging' the existing battery per the following instructions.
This procedure should work for the battery in any Toshiba notebook. Follow it only when you find that the computer will run from the battery for just a short while.
Check the User's Guide for more specific information about charging the battery in your computer .
Procedure
Step-charging the computer's battery
  1. Unplug the AC adapter from the computer, and turn ithe computer on. Let the computer run from battery power until the computer turns off, indicating that the battery is fully discharged. Time this interval, but not with a software clock running on the same computer.
  2. Remove the battery pack from the computer.
  3. Unplug the AC adapter from the computer.
  4. Wait at least 30 seconds. The first time through this procedure, use a soft cloth to wipe the battery pack's contacts and the AC adapter's plug.
  5. Re-insert the battery pack.
  6. Plug into the AC adapter into the computer again and check the fit of its plug in the wall outlet, making sure the connection is secure.
  7. With the computer turned off, let the battery charge until the battery status light or icon glows green, or otherwise indicates a full charge.
  8. Unplug the AC adapter from the computer.
  9. Remove the battery.
  10. Wait at least 30 seconds, then re-insert the battery.
  11. Plug the AC adapter back into the computer.
  12. Let the battery charge again until the battery status light turns green or otherwise indicates a full charge, again.
Repeat this procedure, starting from step 1, at least three times. Each time, check to see if the computer runs longer from its battery than the previous time.
Battery Conditioning:
IMPORTANT!!
Interruptions in the charging cycle can be responsible for an issue called "memory effect" which may reduce the battery's charging capacity. Whenever you suspect the battery performance is not at it's optimum you should try using the following "Battery Conditioning" procedure.
Before you start: Turn off your battery saving features temporarily.
***IMPORTANT*** Repeat the following steps 2-3 times!
  1. Unplug the power cord from the computer
  2. Turn the computer on and let it run until it shuts itself off.
    Note: Using the CD-ROM to play an Audio CD will speed the discharge.
  3. Plug in the power cord (While the system is off) charge the battery until the battery light changes from flashing green to solid green
  4. Remove the battery for 30 seconds and then replace it.
    Note: If the battery light isn't lit, wait a few moments, if it still does not light check your power connections.
  5. Continue charging the battery until the battery light turns solid green once again.
    **REPEAT THIS PROCEDURE 3 TIMES**
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 04, 2008 | Computers & Internet
When i turn my laptop on the fan starts up and sounds like it normally does, then blinks a blue screen up, shuts down then tries to turn on doing the same thing untill i unplug it. Its a Compaq DK587A. ...
Unplugging a computer during reboot is asking for exactly what you are seeing especially with early versions of XP and prior Microsoft operating systems. Why? Because the act of unpluging causes corrupted information to be written back to the hard drive thus creating a faulty reboot, BUT that is not the only cause. I'm gonna ask you if you are knowledage about whether or not the battery on the laptop is charged up or not. If you are sure that the battery is good, then remove the power supply adapter and the cable it used to connect to the laptop and then see if the laptop boots up more or less normally. If it does the it is very possible that the power supply adapter is going bad on you and should be replaced immediately before further damage is done to your system. It is also possible that the first few sectors of your hard drive in the computer have become defective ( more then likely due to unplugging the computer during reboots ). If these first sectors are defective then there is little recourse except to have a technician replace the hard drive but before doing verify that the computer can boot up with a bootable CD or DVD. If it can, then the problem is corruption of the hard drive or fautly hard drive but if it can't, then it is very likely you have a power supply or motherboard issue on the laptop. Replacing the power supply adapter shouldn't be hard but you should make sure you are getting the right one from a trusted vendor. If the problem is a motherboard, then is likely not worth the money to replace it. Replacing the laptop would be a better option then replacing the motherboard. With the slew of defective batteries in recent years, it might be of worth to remove your present battery and then try rebooting just to see if your symptoms change. If they do, your options should be obvious.
Aug 09, 2008 | Computers & Internet
Power supply
You need to charge the battery asa long the charging icon will fully charge , unplug the power observe the condition of the PC if minutes the PC goes off battery need to replace .
Dec 30, 2007 | Toshiba Satellite 1415-S173 Notebook
Laptop shuts off when unplugged, battery is fully charged
Chosenone, Even though the battery meter shows it fully charged I doubt it?s correct. Over time rechargeable batteries loose their ability to store power. How long depends on the battery manufacturer and how well you treat it but you can consider yourself fortunate if your battery lasts three or four years. Beware of people who suggest you take apart your batter to bypass the safeties or replace old battery cells. Defective or improperly handled batteries can overheat and cause fires when you least expect them. Let us know if you have any more questions and please don?t forget to rate this post.
Feb 23, 2007 | Compaq Presario 1200 Notebook
HP Pavilion zd8000 Notebook Logo
162 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
