You don't really "change" the filter. You just clean it. There is a screen filter on the bottom of the oil pump that serves to do a basic filter of the oil going into the oil pump. The real "filter is a centrifugal filter on the right end of the crankshaft. The spinning filter forces the heavy dirt particles to the inner rim of the filter where they build up to a somewhat solid mass. A screw driver pushed into the mass will break the dirt up and when most of the dirt mass is removed, a can of carb cleaner can finish the job. Only minor dis-assembly of the filter is needed to clean it. There is no need to actually remove the filter from the crankshaft.
You can download a free factory service manual at www.carlsalter.com/motorcycle-manuals.asp Please rate my answer. Thanks.
