Question about Farenheit DVD-36 Car DVD Player
Need to use my car radio frequency for my dvd (make is unknown) player but can't figure out which station!
  • 547 Answers
You want to pick a frequency where there isn't an existing station, so the radio will have a clear signal from the dvd player.
If the DVD player only has a few frequencies to choose from, then tune the radio to each one (with the DVD player turned OFF) and see which one has the most static and the least signal from radio stations in your area.
If the DVD player can be set to any frequency, then just pick a frequency (usually down on the "88" side of the FM band) with the least local signal, then set your DVD player to use that frequency.
Does this make sense? Feel free to ask questions with the "add comment" link.
If this solves it for you, please be sure to hit the "thumbs up" for me!
Posted on Feb 09, 2010
  • Pam Keliinoi
    Pam Keliinoi Dec 18, 2012
    How do you check which frequencies your DVD player uses? Mine used to be on an "88" FM band, but now all I get is the station. How do I find a new one or change it?
  • cesar_lara
    cesar_lara Dec 20, 2012
    Hello my name is Cesar Lara and I have the same question as Pam. I have a NESA DVD player in my Tahoe. It's been a while since I used it and I used to have the radio station pre-set with my DVD player since the first day that it was installed and never did memorized the station. It's been several weeks now that my daughter has been wanting to use it but can't because there is picture but no sound at all. I've tried going thru all radio stations on both AM and FM but had no luck so far. Where it Was pre-set before now there is a radio station now and cannot get DVD sound. How can I Find its own station ?
6ya staff
SOURCE:
I DO NOT HAVE INSTRUCTIONS FOR THE AUDIOVOX MVDVD4 DVD PLAYER IN MY VEHICLE AND I AM NOT GETTING THE SOUND. DO I NEED TO TURN MY RADIO TO A CERTAIN FREQUENCY? THANKS
Most FM modulators most commonly run on FM frequency 88.1 or 88.3 but usually have several options, so play arround with the stations in that range, and see if you get sound, also look under the dash for a toggle switch of sorts, sometimes the modulators have to be turned on..
Aug 14, 2009 | Audiovox MVDVD4 Car Video Player
Advent DVD player in vehicle - can't get sound through speakers
I just solved this problem on my Ford Edge 2010. Start the dvd. Hit the FM button on the remote. It will pop up an FM radio frequency in the top left corner of the screen. For example, ours is 88.7. Tune the car radio to that frequency and the sound should come through the speakers. Hope it works for you.
Mar 24, 2009 | Sony MV-900SDS Car DVD Player
No sound for Delphi MV10015 Car DVD Player
if you tune your radio to that channel shown it should pick up and transmit thru radio. you should be able to change the channel frequency to a station without interference from other stations
Jan 30, 2009 | Delphi MV10015 Car DVD Player
Manually change radio stations?
Here is how to manually tune your radio.
1 Press the SOURCE button until a radio
frequency appears in the display.
2 Press the BAND button repeatedly until the
desired radio band is displayed.
Each press changes the band:
→ F1(FM1) → F2(FM2) → AM
3 Press the TUNE button repeatedly until "DX
SEEK" and "SEEK" disappear from the display.
NOTE
The initial mode is DX SEEK.
4 Press the g DN or f UP button to move
downward or upward one step respectively until
the desired station frequency is displayed.
NOTE
The ST indicator or STEREO indicator appears on the
display when a Stereo FM station is tuned in
You can also look at your manual here for any other ? you might have
http://akamaipix.crutchfield.com/Manuals/500/500CDM7874.PDF
Dec 17, 2008 | Alpine CDE-7858 CD Player
Setting radio stations
if it is touch screen you should be able to tune to the frequency required and then press and hold on position 1-7 or wherever u want the station stored and it should store it i hope this helps
Oct 15, 2008 | Car Audio & Video
Dvd player in van no longer has sound
hi i have a toyota van and i have dvd play in it...the dvd player sound works with the radio station but i for got the channel...so cnu help what channel is it spousd to be....write back plzzz
thnks
Jul 18, 2008 | Eiger Vision AV-1301 Car Monitor
No audio
FM station 88.1 or similar. Set radio to scan while dvd is playing. When the correct frequency is reached, you'll hear sound.
May 06, 2007 | Blaupunkt DVD-ME2 Car DVD Player
Poor radio reception
you wanna boast up the radio signal?? There are ant. boasters around, But if your far away from a radio station your radio cant make that weak signal any higher in amplitude. All you would be amplifying is noise or static. Sorry
May 25, 2006 | Jensen VM9410 Car DVD Player
Farenheit DVD-36 Car DVD Player Logo
820 people viewed this question
Top Farenheit Car Audio & Video Experts
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Paul Katynski
Paul Katynski
Are you a Farenheit Car Audio and Video Expert? Answer questions, earn points and help others
