Televison & Video Logo
I have a Alba DVB-T set top box wont change channel
I have a Alba DVB-T set top box, 2 days ago the box stuck on one channel. The pic is fine but the box wont do anything, it wont change channel, cant access menu's etc... the light on the front lights up when you use the remote but nothing happens. It is an old box has it just died? cheers
Posted by emzil on
Marvin
    Top Expert:
  • Televison & ... Master
  • 85,241 Answers
I think you most likely have a failed box problem.
Posted on Feb 17, 2018
5 Related Answers
Anonymous
  • 27 Answers
SOURCE: remote will not work
if the light is staying on this means that a button is stuck down on your remote. It might be defective I would contact the company about warranty.
Posted on Nov 05, 2007
clanprice
SOURCE: DVB not working on panasonic
Check the arial cable - not just the connections. Problem noted was due to an inferior cable that was not up to the job. It also ran alongside a central heating radiotor and pipes - not a good combination apparantly!
Posted on May 05, 2008
Anonymous
SOURCE: Set to box problem
Where did you grab the firmware for it? I can't find it anywhere!
Posted on Sep 01, 2008
Anonymous
SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Posted on Oct 13, 2008
Anonymous
  • 73 Answers
SOURCE: commtel control freak 4in1 control device code for set up
The links to the code are at the bottom of this page
http://www.oneforall-na.com/remote.php?type=URC%203021
the instructions to install/program the codes are here
http://www.oneforall-na.com/set_up_remote.php
Hope that helps,
Please don't forget to rate it Fixit!
Charles
Posted on Jan 11, 2009
Tv will not change channels. Batteries are new. It worked fine 2 days ago.
If the remote you are using will control several devices (TV, DVD player, cable set top box, etc.), make sure you have pressed the TV button, before you try to change channels. Sometimes another device button gets pressed by mistake, so the incorrect codes could be sent to the TV.
My samsung lcd tv stuck on bbc 1 on mono it wont go off screen
pl.see whether the other channels were locked inadvertently 2)if you have set top box remove the connection and connect the cable to antenna slot if you could change channels set top box is defective other wise tuner problem
Alba set top digital freeview box
normally its - press menu - install - scan for channels and then save
something similar to this
hope it helps davetech
1helpful
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
2helpful
I bought an Alba CDVB4 and the remote isn't right
Hi
Not sure if you found the problem for this, but I had the same problem and couldn't find any reference to this except your question so thought I would put up an answer in case it can help you or anyone else.
Aparently, Alba have got hold of the codes that Toshiba use for their remote controls, so if you have a Toshiba telly an Alba product like this won't work. The only solution being to return it and get a different make.
I returned mine twice for a straight exchange thinking it was just a manufacture fault before I found this out. I then exchanged it for a Bush set top box - only a fiver more - and it now works PERFECT!
I hope this helps some.
Zoe
1helpful
I have a Bush DVB-T set top box with no remote how do I program i
I NEED THE DRAWING OF THE CIRCUIT BOARD OF BUSH DVB DFTA 11/A
Commtel control freak 4in1 control device code for set up
Hope that helps,
Charles
4helpful
Top Televison & Video Experts
Marvin
Marvin
