Remove emergency key blade from top of remote
Open door manually
It just clips out
It will show you in owners manual,but that is in the car it won,t help
Sound like flat battery, if so key won,t turn untill you charge it
SOURCE: 2004 CHEROKEE, WONT RECONIZE DRIVERS DOOR OPEN,
its the ground wire for the driver door, and posably an ornge one, in the black shielding to the door they rip all the time but yet for some reason jeep has yet to make a recall. any who you disconect the battery then pull the shielding back and patch the wires together.
SOURCE: My door locks don't work, and my remote will only open the driver
Check door switch connection under door pad in drivers door. Sounds like the electrical connection that sends power from the main door (drivers side) to other door has failed or wiggled loose.
SOURCE: drivers door power lock wont work.
Either the wring going to that motor or the motor itself is bad.
SOURCE: doors wont open with keyless remote.
I am taking the truck up to the lock smith and having it re-programed. This should take care of the problem.
SOURCE: remote fob and power lock buttons wont unlock or
Unless the batteries on your key have run flat and need replacement, the key needs reprogramming. Advanced diagnostics at an authorised service centre will sort both issues pretty fast.
