RIM BlackBerry  Pearl  8100 Logo
Posted on Oct 08, 2017
BB 8800+application error 523+reset
Hi!
Thanks for helping me! My blackberry 8800 stopped fonctionning after i had on a programm. When i start it, it is wrotten "application error 523 and reset " on the screen. Some says it must be flashed once again. Would someone help me to reslove it? It possible to download freely an appropriate hard reset programm?
Thanks...
5 Related Answers
Anonymous
  • 95 Answers
  • Posted on Aug 10, 2008
SOURCE: My Blackberry flashing red, not starting up - 8800
it's locked and needs to be googled for a detailed fix
Anonymous
  • 46 Answers
  • Posted on Sep 17, 2008
SOURCE: unlocking BB 8800
you can get the unlock code here: http://www.gsmunlocklabs.com/unlock-cingular-blackberry-c-41_42.html
Anonymous
  • Posted on Dec 14, 2008
SOURCE: USB connection failure to Blackberry 8800
I have the same problem.  The following solution may apply; here is how to IDENTIFY the problem: (1) Phone doesn't connect to desktop software through USB but will through BT (if setup) (2) Phone doesn't charge whether USB-computer, USB-wall, USB-carcharger or does sometimes but you are not sure why it works sometimes but not all the time (3) If you hold, lean, twist, or jiggle the plug at the phone, it may charge or the charge icon may show briefly (Also) Plug is noticeably loose or comes out Solution: if plug is torn loose, damaged, or comes all the way out, go to this site and follow along in kind http://computerguru365.blogspot.com/2006/02/diy-blackberry-usb-repair.html If plug is simply intermittant: remove all power and the battery, open your phone, and carefully redo the solder joints of the plug.  If you don't have a SMT (surface mount) rated soldering iron w/ tip, you can use the radio shack standard but be sure to only apply the hot tip in pulses (less than/up to 50% of time, less than 3sec each touch) so you don't heat damage the surrounding components. Why: Because the plug gets tugged to the sides causing the solder joints to crack (microscopically).  At first I had to lean books against the plug but then that quit working as well.
This approach also worked on my laptop which quit charging when plug torque flexed the motherboard and cracked the solder at some surface components near the plug.  I found out which components when the varying the force of my multimeter tip cause the component to show open and normal across the solder joint
Anonymous
  • Posted on Jun 27, 2009
SOURCE: blackberry 8310 app error 523
how can i fix error 523 on a blackberry 8830
Anonymous
  • 3 Answers
  • Posted on Oct 04, 2009
SOURCE: how do i solve the APP Error 523 on blackberry
I had this same problem it was from a third party application that I had downloaded. Go to blackberry.com, and select support and search your APP error it will walk you through a guide on getting it fixed--although your phone will reset back to default.
Hi there, I hope someone can assist me with this
Sometimes it helps to upgrade your OS ...from say (a)4.2.0.442 to say (b)5.0.0.1015. I was getting tons of uncaught applications on my 9550.I upgraded from (a) to (b) and the problem is gone.Along with battery issues.Can you try that?Your carrier must have OS upgrades for your device on their website.Good luck!
1helpful
When i switch on my blackberry 8520 then i get a error app error 523
hi krup patel00 you have an application software crash on your phone. you need the bb desktop manager to reload you apliation back on to the phone.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
2helpful
13helpful
3answers
Blackberry 9630 App error 523
Hi, error 523 reset means a "System process died" You'll need to reload the entire handheld OS again.
1. Install the software from the CD (that you received with the device), or download it from the service provider.
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the phone
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes...
Take care
Mar 01, 2010 • Cell Phones
2helpful
BB messenger error "Uncaught Exception: java.lang.null...
When attempting to send messages from the BlackBerry device, the BlackBerry device user receives the following Java error called uncaught exception java.lang.illegal argument exception:
To over come this error you need to complete the following steps:
First, perform a full backup of the BlackBerry device data:
  1. Connect the BlackBerry device to the computer using the USB cable.
  2. Open BlackBerry Desktop Manager, and then double-click Backup and Restore.
  3. Click Backup.
  4. Save the backup file.
Run the application loader tool and erase all data on the BlackBerry device:
  1. In BlackBerry Desktop Manager, double-click Application Loader.
  2. Click Next.
  3. On the Device Security Password screen, type the BlackBerry device security password, and then click Next.
  4. On the Device Application Selection screen, click Next.
  5. On the Completing the Application Loader Wizard screen, click Advanced. The Device Data Preservation screen is displayed.
  6. Select the Erase all application data check box, and then click Next.
  7. Select Do not automatically back up and restore the device application data during the loading process, and then click Next.
  8. Click Finish. The BlackBerry device resets. This might take several minutes.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
7helpful
3answers
How do i solve the APP Error 523 on blackberry tour. I have no password set, i have the OS version 4.7 on the blackberry device. The device loads and shows the error APP Error 523 and reset. Upon reset it...
2answers
App error 523
On the BlackBerry smartphone, the following error message appears after pressing the mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, the BlackBerry Device software will have to be reloaded.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry Desktop Manager. Please proceed to open and run the Application Loader.
7helpful
4answers
App error 523 reset
I got error code 523 after did the device software upgrading. Please advise. tks
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
