Question about Krups Kitchen Appliances - Others
Hi, I have been trying to find out whether my Krups electric kettle "TYPE 856" is PBA-free, as I have read that heating water in a BPA containing plastic is particularly to be avoided. Do you have information about this? Thanks. Also, if it does contain BPAs, will Krups issue a credit toward replacing it, since it is unsafe to use?
SOURCE: The left side of my Krups Duothek Plus 464 is not working
How to Repair a Coffee
Maker
http://home.howstuffworks.com/how-to-repair-small-appliances3.htm
Posted on Mar 03, 2009
SOURCE: krups electric kettle leaks
You cannot fix it when they split like that.
Posted on Apr 01, 2010
I was successful at fixing my Krups Electric Kettle for $4. In my case the water was leaking from bottom somewhere close to the heating area. I think that a small hole was created in the seal around the heating area in the bottom of the inside of the kettle. One can try to find the general location of the leak by putting a small amount of water in the kettle, place the kettle in a larger pan, and tilt the kettle so that the water is slightly higher than the heating area in one area only, noting the position where the water level is above the heating area. Leave it for a while and check for leakage. If there is none, rotate the kettle a few degrees so that you have a new high point and look again for leakage from the new area until you find the area where it is leaking. Alternatively you may wish to put a sealant around the entire area, 360 degrees, around the top of the heating area. You mayl have to remove the strainer first to get your hand in the kettle to apply the sealant.
I went to my local hardware store and looked for sealants that were:
1. Potable (ie safe since you will be using the water for coffee, tea, and other applications that you ingest).
2. That will withstand heat up to at least 250 degrees Fahrenheit. Remember that water boils at 212 degrees.
I found epoxies that required mixing two compounds but decided that this would be difficult to deal with and apply. In the end I bought "PC Plumbing Epoxy Putty" from PC-Products. This met both requirements and was easy yo use. You take the putty and roll it between your finger just like you did in kindergarten with the clay and make a thin string that you could position in the crevice around the top of the heating area. You may either cover the area where you found the leak or the entire 360 degrees. You will note a somewhat foul smell of the putty. The manufacturers says that it will cure in 3 hours. I found that the smell went away when it completely dried and hardened after 3 weeks!.
I will assume that the same solution is applicable to leaks in other areas of the kettle. I have also found that there are equivalent electric kettles much cheaper than Krups. I would certainly check the construction to see if there is one with less of a chance to develop a leak.
But the bottom line is that it cost me $4. I just finished testing the Electric Kettle and it is fine, not leaking, and the instant coffee did not have any bad smell.
Meir Elazar
Posted on Feb 12, 2011
needs a new element and if it is an induction heater ( jug sits on a base to heat the water --junk it and get a new one
Posted on Sep 24, 2018
