2002 Jaguar X-Type Logo
Anonymous Posted on Jan 31, 2010
Key fobs not working i have changed the battries on both
Anonymous
Level 3:
  • Master 510 Answers
  • Posted on Jan 31, 2010
Anonymous
Master
Level 3:
Answers
510
Questions
0
Helped
384119
Points
1812
: If a double audible warning sounds during the programming procedure a system malfunction has occurred. Repeat programming procedure.
Obtain all keys fitted with remote control. Open driver's door. Operate headlamp high/low beam switch to flash high beam position and hold. Insert key into ignition switch, turn to ACC position. Ensure system LED flashes once and an audible warning sounds. Operate headlamp high/low beam switch to flash high beam position 5 times. Ensure system LED flashes once and an audible warning sounds. Programming mode activated: Press and release lock or unlock button on first key. Ensure system LED flashes once and an audible warning sounds to indicate correct programming. Repeat programming procedure for remaining keys. Switch ignition OFF and remove key. Close driver's door. Check operation of keys. Keys can also be programmed using diagnostic equipment
Changed battery on my key fob and it won't work
What is year--make--model?
The key fob is a transmitter so there has to be a receiver in the vehicle. At the moment, I can't tell if problem with transmitter or receiver? Can you try a different key fob? Where applicable, if key fob needs to be programmed, maybe the info is in your owners manual?
How do i open my door when my car battry dies and my door locking is sticking, and it wont work by the key fob????
The biggest reason this happens is because no one uses the key to unlock doors. The cylinders in the key slots loose their lube and get stuck in a certain position(corrosion). Spray some lube in it(wd40) and work the key in and out. Spray more lube. Work it more. This may release your locks, but is no guaranty. You may have t have a lock smith come out and fix it.
Programe key fob ml270 2004
MB car
dead fob?
all cars come with 2 working fobs.
so are both dead, (key fact this, saves huge labor)?
sig: I asks questions, because I'm blind and my tools can't reach.
Key fob has new battries, cant start, lock or unlockbysensors
See if there is a fuse for the keyless entry system / computer...
Fob will not work changed battries and still no luck
lost one of the key fobs to a 2007 mercury montego. dealer gave me a used one for free and instructed me to turn ignition key on and off 12 times but without starting the car. next, try key fob. worked for me. if you have 2 key fobs, you may have to reprogram both, so i would change batteries in the other one as well, but only after the non working one proves good.
Top Jaguar Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jaguar Expert? Answer questions, earn points and help others
