www.manualslib.com > ... > Sanyo Manuals > CD Player > FXCD-500 FXCD-500 CD Player pdf manual download. ... cause a deterioration in the sound or intermittent skipping some tracks during play This unit has ... TAPE OPERATION 109876 LOADING AND EJECTING THE TAPE Insert a cassette into the tape ..
The eject button is stuck (probably got some stuff splashed on it). Take the face plate off and clean/check area around this button for goo, dirt, or damage.
Does it make noise or move when you hit the eject button? If so, slide a butter knife under the exposed edge of the tape drive adaptor about an 1/8" and hit the eject button. Just a little upward pressure should help it release. It the eject button has no effect, you may need to pull the radio out, open the cover and manually turn the eject drive assembly.
The conventional wisdom is to lever underneath the front edge of the cassette with a flat blade, while tugging on it with needle nose pliers, and with your spare hand (or toe) pressing the eject button. If this does not work, the player will have to come out of the dash, and have its outer case removed. This may assist
Then I unscrewed the bottom panel of the radio. Unscrew the brass screws holding in the cassette player portion of the radio. Now flip the cassette player over to see your tape, etc. When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound. I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
sometime you can get luck by taking out the tape player and there will be a small hole somewhere on the player that you can stick a paper clip through to release the tape player. Otherwise gnetly stick a screwdriver under the tape to see if you can get it to release. no guarntees on that last one
no question is silly ,it may draw juice if the power it's direct,when you turn the key on off and the cassette is still movinig or ,at the same time do this push eject & with a some thin screwdriver or pencil pull cassette out this is an old trick help me menny of times..good looking
