Cars & Trucks Logo
Posted on Jan 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set the floats on 1980 honda fcivic
How to set the floats height on 1980 honda civic
Jonah Oneal
Level 3:
  • Honda Master 14,092 Answers
  • Posted on Jan 30, 2010
Jonah Oneal
Honda Master
Level 3:
Answers
14092
Questions
0
Helped
7241345
Points
44533
YOU CHECK FLOAT LEVEL LOOKING AT THE SIGHT GLASS ON THE RIGHT OF THE CARBURETOR.FUEL LEVEL SHOULD ALIGN WITH THE DOT ON THE SIGHT GLASS.IF THE LEVEL IS ABOVE OR UNDER THE DOT THE CARBURETOR HAS TO BE DISASSEMBLED.TO SET FLOATS REMOVE AND INVERT THE AIR HORN UNTIL THE FLOAT ARM JUST TOUCHES THE NEEDLEVALVE OR THERE IS ABOUT 0.1 mm OR 0.004 INCH CLEARANCE BETWEEN THEM.MEASURE THE DISTANCE BETWEEN THE BOTTOM OF THE AIR HORN GASKET INSTALLED.AND THE CENTER OF THE BOTTOM OF THE FLOAT.THE DISTANCE SHOULD MEASURE 36.4 mm 1.39 - 1.47 INCH. ADJUST BY TURNING THE NEEDLE VALVE SEAT.BE CAREFUL NOT TO ALLOW THE VALVE SEAT TO PROTRUDE FROM THE SEAT ATTACHING BOSS.WHICH WOULD ALLOW THE VALVE TO FALL.IF THIS IS THE CASE BEND THE FLOAT ARM SLIGHTLY UNTIL PROPER CLEARANCE CAN BE OBTAINED.WHEN CARBURETOR IS INSTALLED CHECK FLOAT LEVEL BY LOOKING INTO THE CARBURETOR FLOAT SIGHT GLASS I MENTION IN INFORMATION ABOVE.IF YOU HAVE A 1487cc AND 1600cc CVCC MODELS WITH THE KEIHIN 3 BARREL CARBURETOR.THIS WOULD DEALERSHIP JOB.THIS TYPE IS HARD TO ADJUST.
  • pollox Jan 03, 2016
    How do you adjust the float without a sight glass on a keihin 2 barrel honda civic carb? I have no aces to a float gauge as I'm in Thailand. Honda don't have a clue as they are all fine.
1980 Honda Civic 1300 DX. How to replace front brakes please?
in pairs yes.
take a class on auto repair , brakes
we dont ever just replace parts
we inspect every inch first. for lots of things.short list 101
  1. no leaks Dot3/4
  2. pistons not seized in say calipers.
  3. clipper slider pins not seized,
  4. wheel bearings not bad. oops
  5. rotors not cracked , not warped or too thin.
  6. new pads. sure.
  7. check suspension part for too loose and like he danger of ball joints bad or near failure, tie rod ends of any kind.
  8. shock;/struts not bad.
  9. OMG tires bald or wore,budges or de-lamination. etc.
  10. bent parts all there. or cracks there, all that. there.
the job is first inspection not just throwing parts.
all this is possible danger if bad. ever have ball joint fail at 60mph?
or cracked rotor lock up at speed.
oops
1helpful
What is the power of engine honda civic sedan 1980
In 1980, Honda Civic is available in two engine. One is 1335 cc (1300) CVCC engine made 55 hp while the other is 1488 cc (1500) CVCC engine produced 67 hp (50 kW). Honda civic offers 4-speed manual and 3-speed automatic transmission. These both engines of Honda Civic available in base and DX versions.
If your interested to know more about the Honda Civic 2017.
Does a honda ballade 150i have a crankshaft sensor
what year? They've been made with many changes since 1980. I would take the dist cap off and see if it spins when the motor turns. If not, then the timing belt or something else is wrong. If it does, then the dist may be bad. (it's sold as a Honda Civic in the USA)
1980 Civic with one low beam not working
have you checked fuse box? they do have separate fuses for high and low beams. or your headlamp could just be bad, (burned out low beam)
1helpful
Changing the timing belt on a 1980 honda civic
Hi Sumbreez, The Civic uses a timing belt which requires replacement every hundred thousand kl. I'm not sure if it has a clearance engine, but have a vague memory of the valves being damaged if the belt breaks. If the valve are damaged, it is more than a possibility that the pistons and maybe the con rods will also be damaged. To answer the rebuild question, is one you will need to answer yourself, as that will depend on your global location. If you're in Africa with little cash, rebuild it. If you're in the States with little cash and prepared to do it yourself rebuild it. If you're in the States with little cash and need to have a workshop rebuild it, throw it away. Regards John
Is the lfloat to the gas tank of honda civic 2001 big problem
No I have not seen any unusual levels of problems with the fuel level sensor float
Need a free manual download for a 1983 honda civic wagon. or help. need to know how to change the carburetor float and how to calibrate the floats.
go to autozone.com, they have access to free repair manuals online. you will need to sign up, provide information about your car, and search in the Do It Yourself area. the cost is FREE!. best of Luck!
Were is the float chamber on i honda civic
The float chamber is in the underside of the carburator if this is a carburated car.
If the float is in fact shutting off the fuel to the carburator the engine should still run on the fuel in the float bowl. Unless it is a very long sharp turn. Have you tried standing still and just turning the wheel hard to the right and see id the engine cuts out ? If it does you may have an exposed wire that touches somewhere when steering is all the way over to one side.
Hope this helps
Sam
I have a 1980 honda accrod 1.8 li....
The nob on the back is the idel set., the float adjustments are the 2 recessed areas on diverside on top of carb.. Be aware by turning to try to set float can cause problems. If you do turn be sure to count number of turns for each so you can reset to original settings if carb starts to flood or starve. What are you trying to acheive?
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
