Motorola Mobility TracFone C139-4 Cellular Phone Logo
Posted on Jan 29, 2010
Vibrate how can i place the option to make vibrate my phone step by step?
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Feb 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
14192
Points
46
1 go to settings
2. ring style
3. click the little button top left on phone under "select". it will let you change your ring style
4. scroll to vibrate
5. click same little button under "select"
6. keep clicking "back" - the little button top right on phone under "back"
Cell phone contacts
Step 1Remove the SIM card from your Motorola phone. The SIM card is a small chip that is located under the battery in your cell phone. After you've removed the SIM card from your Motorola phone, remove the SIM card from your LG phone.
Step 2Insert the SIM card from your LG phone into your Motorola phone. Turn on the Motorola phone.
Step 3Press the "Menu" key and select the "Address Book" option.
Step 4Select "Options" by pressing the right soft key. The "Select Multiple to" option will appear on the screen. Choose the "Select Multiple To" option and then select "Copy to SIM to Phone."
Step 5Remove the SIM card that you placed in your Motorola phone and insert it in your LG phone. After inserting the SIM card, turn on your LG phone.
Step 6Click the "Menu" key on your LG phone and select the "Address Book" option.
Step 7Select "Options" and choose the "SIM Management" option.
Step 8Select the "Copy from SIM" option and choose "Select All."
Step 9Select the "Copy" option. Your contacts will be transferred from your SIM card to your LG phone.
Vibration pattern
Click Here to Email SUpport for a step by step instructions.
My lg shine is on vibrate. How do I get it to vibrate and ring? I'm not to good with these things. I'll need step by step. (sorry)
I really tried searching for the options but as every phone has a different feature, so I woudl recommend you to go the link mentioned below:
http://www.scribd.com/doc/14125017/Lg-Shine-Ke970
The manual contains all the options and you need to scroll down to page 37 of the manual.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
2answers
SE K850i touch option
use the laser precision theme in silent mode(with vibration).
1helpful
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
10helpful
How to turn on vibration on my samsung SGH-L700
Step 1) Move to the MENU of the phone.
Step 2) Press # or Select SETTINGS.
Step 3) Press 1 or Select PHONE PROFILES.
Step 4) Now Select the profile u want to edit & click on option
Step 5) Now the opened list will contain 2 opitons 1. Save and 2.Edit.
Step 6) Select 2.Edit.
Step 7) Select the first option call alert type .
1helpful
How do I get a message arlet tone on a blackberry 8700v smartphone?
Want to change the tone you hear when you get an SMS, MMS, or IM? Want to change the ringer for the phone? Follow these directions to edit the Profiles area on the device:
1. Select the Profiles icon
2. A box will appear where you can quick select between Loud, Vibrate, Quiet, Normal, Phone Only, and Off. If you wish to quick change the device profiles then select the one you want and exit out.
3. If you want to edit the tones assigned to the device applications then select the last option, Advanced
(some older models and OS 4.1 and below will not have the "Advanced" step--if Advanced is not present go directly to Step 4 below).
4. Select the profile you wish to edit. (Loud, Vibrate, Quiet, Normal (default), Phone Only, Off)
Note: on the 8100, 8800, and 8300 models: Do not click the trackball. Instead, click the menu key to the left of the trackball).
Note: The profile that is in use will say: (Active)
5. You will now see a list of all applications that can have a tone assigned (Browser, Calendar, Level 1 Messages, Messages ([email protected]), Messenger, MMS, Phone, SMS, Task ect..)
6. Select the application you wish to edit the tone / notification for
7. You can now edit Out of Holster and In Holster tones/ notifications.
a) Select between: None, Tone, Vibrate, Vibrate+Tone
b) Select the Tune you wish to use
c) Select Volume (options are Mute, Low, Medium, High, Escalating)
d) Select Number of Beeps (options are 1, 2, 3)
e) Select Repeat Notification (options are None, LED Flashing)
f) If set to Vibrate or Vibrate+Tone then select Number of Vibrations (options are 1, 2, 3)
8. Repeat a-e for each of the desired applications listed in 5 above
Good luck. If this helps you plz rate this. Thank you kindly.
Jan 31, 2009 • Cell Phones
1helpful
2answers
******** function on Nokia 2610
Go to PROFILES and the one that is highlighted select CUSTOMIZE and you should see your RING options there/. Make sure you SAVE before you exit out.
2helpful
2answers
Turn vibrate on ?
let me sole it by steps do it step wise
press
1. menu 2. profiles 3. general 4. personalize
then move down to incoming call alert than select off
and move vibration select on
did i solve the problem
Jun 14, 2008 • Cell Phones
8helpful
3answers
Samsung d900
To place the handset in silent / vibrate mode follow the steps below: To place the handset in Silent Mode, hold down the pound key (#) for about 2 seconds. To exit Silent Mode, perform the same action while in Silent Mode. You will see a confirmation message for Silent Mode, each time you enter or exit Silent Mode. The phone will vibrate rather than ring when you receive a phone call, message or alert while in silent / vibrate mode.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
