SOURCE: Need Repair for OL-3000
All programing functions are controlled on the main (stationary) board. All display functions are controlled on the Rotor (spinning board.) Here are some steps to take if you are having display problems. Remove the three mounting screws that hold the rotor to the motor shaft. The LED display board is attached perpendicular to the rotor board and is soldered to the rotor board. Over time, the connections break due to the centrifugal force of the spinning rotor. CAREFULLY, with a low amp solder iron and a fine tip, re-heat the board to the display. That should solve the problem. If you were a bit sloppy with the solder, remove the solder with a fine wick and try again!
SOURCE: Olympia Globe Caller ID
I just printed a manual in pdf form go to,http//smarthome.com/manuals/5109.pdf
SOURCE: how to change time on Olympia Infoglobe caller id
I have the manual and can tell you what it says:
(this worked for me last year when we went off daylight savings, but for some reason, It doesnt seem to work anymore. I can't imagine that I did anything different then. You can try, though.)
Enter (or leave) the Demonstration Mode by pressing the right key for at least 1 second.
Then, by pressing SELECT key, you are SUPPOSED to be able to scan a menu which lets you pick date format, time format, etc.
This no longer works for me, and the instructions also have a contradictory comment that says the SELECT key is disabled in this mode. But perhaps this will work for you.
I would also appreciate instructions if anyone knows what I am doing wrong.
