Left ligh keeps flashing. after installing new ink.
Please rate my response!!
Solution
A}}}}}.....
1. Open the top cover of the printer, the RESUME light will flash and the print cartridge cradle will move to the center of the printer.
2. Lift up one of the print cartridge latches.
3. Grasp the top of the print cartridge and pull it out of its cradle.
4. Repeat Steps 2 and 3 for the other print cartridge.
NOTE: If you are going to insert new cartridges or are having problems with the cartridges that you are using, make sure that you have removed any tape covering the ink nozzles and do not touch the ink nozzles or the gold-covered contacts.
5. To insert each cartridge, tilt the cartridge towards you as you are inserting it into its cradle.
6. Push the cartridge down firmly into its cradle slot.
7. Close the print cartridge latch.
8. Make sure that you have completed Steps 5-7 for each cartridge.
9. Close the top cover of the printer
The RESUME light should stop flashing.
Problem
B}}}}}}......
The print cartridge contacts are dirty.
Solution
1. Open the top of the printer, the RESUME light will flash and the print cartridge cradle will move to the center of the printer.
5. Clean each print cartridge with a clean, dry, lint-free cloth to clean each print cartridge by wiping once from the bottom of the copper contact strip to the top.
6. To insert each cartridge, tilt the cartridge towards you as you are inserting it into its cradle.
7. Push the cartridge down firmly into its cradle slot.
8. Close the print cartridge latch.
9. Make sure that you have completed steps 5-8 for each cartridge.
10. Close the top cover of the printer.
